Results 1 to 10 of 10
Thread: LB7 Y bridge connection-What wire goes here?
    Powhatan, VA
    Default LB7 Y bridge connection-What wire goes here?
    Been working on my truck for a while and can't remember what wire connects to the y bridge and am not finding a wire that wants to connect there. Any help please. This is a 2002 duramax. Thanks!
    2002 2500HD duramax/allison Ext. Cab, Long bed, gray, bed rug, fumoto valve, dta running boards, peragon cover,amsoil
    Which connector? The loose nut on the pipe below the intake heater? Support bracket, perhaps? Can't see it on an assembled engine, it's buried under the compressor inlet (I looked). The diagram shows the stud, but makes NO mention of it.
    Powhatan, VA
    yes, the loose nut (loose in my picture) below the intake heater. I know it is buried under stuff when everything is together, that is why I don't want to continue to put things back together without knowing what should be connected there. I don't think it could be much more than a ground, but want to see if anyone knows for sure.
    I thought about a ground, at first, but a bracket and the close position to the fuel pipes seemed to make more sense, at the time. Perhaps the heater ground, rather than grounding it through the manifolds. The diagrams don't mention or show it, and it isn't listed on the ground distribution chart.
    Powhatan, VA
    Thanks for checking on the diagrams. That is a good thought about a bracket. I do have an extra bendable wire holder that I wasn't sure where it went and that could be the place--although there doesn't seem to be a wire next to it there are some in the area.
    If anyone has a chance to look at their LB7 and can see in there, please let me know!
    Thanks DmaxMaverick!
    Ken
    There was a strap I believe that went around the barrel of the fuel pressure relief valve that extends from the function block.
    Looks like: =====O with a break in the side of the O of course.
    Powhatan, VA
    Thanks, John! I will look around to see if I have anything like that lying around.
    Powhatan, VA
    That was it! A metal strap lined with rubber. Thanks for everyone's response!
    Ft. Wayne, In.
    Ken,
    Isn't this place awesome!
    Having guys around like Kennedy and DMAX is priceless!
    d
    Dave, N9LOV
    Member #242
    Dave's Diesels:
    '97 2 Dr Tahoe, Intercooled,
    Kennedy ECM, 4" Exhaust
    '02 GMC
    Quote Originally Posted by KenZ View Post
    Did you take a pic of it, in place, before sealing it in the tomb? If you did, please post it here, and be the only one anywhere on the web!
