![Quote](images/misc/quote_icon.png)
Originally Posted by
Robyn
The 6.5 has always been a problem child when it comes to keeping the temp in check in hot weather and when the rig is worked hard.
Every truck we have had here has to some extent been fussy in hot weather, even when new.
With the dual thermostats, HO water pump, modified fan clutch, and all-aluminum radiator, I finally feel comfortable when towing and no longer have to keep my eyes glued on the temperature gauge. I still have to back off the throttle some on mountain passes, but now the engine stays pretty much a constant temperature under load: right in the middle of the gauge.
