2 New Seals Leaking - Please Help
Finished resealing my valve covers with Right Stuff. Those are doing great.
I also replaced my harmonic balancer and front crank seal, as well as, the oil pan gasket (which has the Fel-Pro gasket and the rear rubber pan seal).
It’s the front crank seal and the rear rubber pan seal that are leaking, and they leak pretty bad too.
The rear pan seal I get. I should have used Right Stuff silicone along with it.
But it’s the front crank seal that i don’t understand why it’s leaking.
Any thoughts? I need to try to get this fixed this week.
Thanks in advance! I really appreciate it.
1988 K10 Suburban. 6.5L NA Goodwrench Engine: 506 block cast on August 12, 1996. Heavy Duty built 700R4. Full-floating 14 bolt rear axle. 3/4ton 10 bolt front. Brand new 305/75R16 Procomp AT Sport tires on brand new 16x8 steel wheels.
