Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: skipping on deceleration?
    Feb 2017
    Jonesboro, GA, USA
    Default skipping on deceleration?
    96 GMC 6.5; 275K
    Love my truck, but don't drive it much anymore. Last few times I took it out it would occasionally skip (kick - sputter) but only on deceleration. Seems to do it more when I accelerate hard then let of the throttle.
    If I put it in N and coast, it quits. If I give it a little throttle it quits.
    Doesn't skip at idle, or during acceleration (still has good power).
    PCM going maybe? It's been several years since I replaced it, although it's on a heat block.
    Any suggestions as to where I should start? Never had this before . . . . I'm at a loss . . . .
    Hello
    Welcome to TDP...
    Has the check engine light come on ???
    If the light has been on get the codes.
    If no codes showing then the PMD (MOUNTED ON THE COOLER BLOCK) is a suspect.
    Any other anomalies ????
    Make sure all the battery cables (both ends) are clean and tight.
    Check the voltage at both batteries... both need to read the same.
    Should read about 14 volts with engine running.
    Voltage anomalies can cause issues....
    I'd also recommend spending some time in the following forum topic thread on "Stalling".
    https://www.thedieselpageforums.com/...ead.php?t=2938
    A lot of what is mentioned there will apply to your situation.
    Nov 2002
    Martinsville, IN
    This can happen if the FSD is failing.
    If this truck is a 1500 series, the problem could also be related to some failure or poorly performing component in the EGR system.
    I was recently experiencing "hiccups" and stalling. Pulled the MAP sensor and charge temperature sender, cleaned them both with MAP sensor cleaner, cleaned the electrical connections, coated the electrical connections with dielectric grease, installed them and plugged everything back together, and haven't had any issues since. Something to try before going too deep into PMDs and such.
    Diesel Page Member #2423
    Feb 2017
    Jonesboro, GA, USA
    Thank you all for your suggestions. I've been unable to get back here since my post, I apologize.
    Since my original post date:
    I drove it one night and left it idling while I was talking to someone. It began to kick and sputter, then suddenly began to rev up, 4000+ RPM. My wife was in the truck and turned it off.
    when I got back to the truck, it cranked perfect but really kicked and coughed as I eased down the road and then again it began high rev's! I put it in N and cut it off and coasted for a while.
    Then, re-cranked (perfect crank) and kicking and sputtering I moved on back home. But I noticed that I had NO Throttle a all. Pushing the pedal did absolutely nothing. I had to only use the erratic kick/sputter at idle to get me back home.
    My thought was a PMD (FSD) also. But wanted my expert friends to reassure me. Thank you.
    Cheap ones on eBay from Ricky's Performance Parts . . . . but no brand name. Not sure it they're any good. But he has 99.8% after 46K+ sales. Must not be a bad person.
    Is Stanadyne still any good?
    The high reving is the least common failure of the PMD, BUT THE MOST EXCITING.
    Get a fresh PMD ON THE BEAST
    I prefer the the DTECH
    Feb 2017
    Jonesboro, GA, USA
    Thanks!
    Yeah . . . . it'll get your blood flowing! I'm just glad it didn't blow up! HA!
    Looking for one now. Don't see much DTech's. I wonder if Rudy's is a DTech?
    The engine will not reach dangerous speed.
    Once it reaches RED LINE the ECM will shut it off.
    The wild part is when it's in gear and takes off and you try to corral it with the brakes and it starts brodying around smoking the tires
    This type of failure is the prime reason that the round tall shut off solenoid is on the injection pump.
    That sucker shuts off all fuel flow to the pump.
    I have had these take off while I was under the hood..
    They howl, smoke up the area big time and then shut down.
    https://www.ebay.com/itm/Flight-Syst...YAAOSwrx5UYTQR
    Quote Originally Posted by drgerry View Post
    The PMD isn't something I'd cheap out on. Even the good ones seem to fail after time. The cheap ones aren't likely to last long - but at least a few months or years, which is long enough to get a good review.
    Quote Originally Posted by trbankii View Post
    Ebay seller feedback ratings are almost exclusively based on the seller and the process of the transaction, not necessarily the items they sell. As trbankii said, even a bad PMD will likely last longer than the feedback period is allowed, which is fairly short. Usually, if they work once, they'll work for a while. Even new from reputable retailers can be bad right out of the box, so it's really a mixed bag, and a risk in any case. If you read the feedback, you'll see that the vast majority of them mention nothing of the longevity of an item that's correct, undamaged, and delivered on time. I buy a lot from ebay sellers, and likewise, if I get the item I ordered on time and undamaged, I submit the feedback as soon as I know the item works as advertised. As far as seller-stated warranties go, unless it's a manufacturer's warranty, none of them are good after 30 days. Ebay only allows complaints within 30 days of delivery, and the seller isn't obligated to respond after that. Also, unless the seller is also a reputable retailer outside ebay, many manufacturer's don't accept ebay transaction receipts as valid for warranty service. I've seen it go both ways. Buyer beware.
    Feb 2017
    Jonesboro, GA, USA
    I ended up having to get a Dorman PMD from a local auto parts store. I need the truck and couldn't wait.
    It solved the problem . . . .
    Thanks to all for sharing!!!
    At least you know what the situation is now and in the interim you can get a Dtech or a flight systems and have in the glove box...
    Which resistor did you use in the PMD plug ??
  15. #15
    Sep 2001
    Lubbock TX, USA
    The cheap PMD's that are unmarked are Dorman clones. Dorman made their copy of the PMD module by having them made in China. Typical China once you make something there, they tend to make your product and sell it as their own, this is where the cheap ebay modules are coming from.
    The Dorman PMD has been something I stay away from after experiencing high failure rate on customer rigs, and when they fail they do the runaway condition described in this thread by Robyn and indicated by the thread originator. They're scary and not worth the risk of wreck or engine damage to save some bucks.
    Only really two options for quality PMD. The Flight and D-Tech units and Stanadyne (either black or gray).
    Only issue with the Stanadyne gray unit is that is is less resilient to heat (not as thick) so it must be placed on a good heat sync out of the engine by or on the pump as designed to last. When these fail, they just do the classic stall and start back up situation.
  16. #16
    I have had very good experience with the D-Tech units myself. That's my personal preference.
  17. #17
    I will not use the Standayne units for one reason.
    Back in the hay day of the 6.5 there was pretty much ZIP ZILCH NADA help from anyone when it came to fixing the PMD failure issues.
    GM did little and Stanadyne was little better.
    The aftermarket figured out that the PMD was the "Fuse" and the only solution with the available parts was to keep the thing as cool as possible by whatever means available.
    Sure seems to me that the big boys at Stanadyne could have fixed the design flaw and made a top notch replacement available for a decent price.
    Most 6.5 owners would have happily sprung for something good....
    GM hatched this abortion and could not wait to off it in favor of it's next hatchling...
    I will support Flight systems or DTECH on this one.
    GM could have done a common rail on this engine, but went with the cheap fix.
  18. #18
    [snip]
    Pretty much my analysis of the situation as well. Further, Flight Systems is just down the road from me (Lewisberry, Pennsylvania) - actually, within a stone's throw of the high school I went to - and I'll happily support a local business that I know to be a quality operation (I know a number of people that work there). I cannot say if any of them are specifically involved in the 6.5TD PMD - I'll have to ask around as I run into people.
    I also found this paper prepared by DTech about the DTech/Flight Systems PMD and Stanadyne's response to them: http://pmdfailures.com/files/DTechDS...formation1.pdf
    One item that I noted from that paper:
    GM 6.5L engine owners should be made aware that most of the issues encountered with this application are actually caused by other sources such as: faulty ignition switches, electrical connectors, oil pressure sending units, PCM problems etc.
    And DTech's response:
    It is curious that now that there is a an alternative product available, Stanadyne now embraces the idea that "other sources" are the problem, yet continues to build large quantities of PMD replacement modules?
    So, before replacing a PMD, should one typically go through and replace the ignition switch, OPS, etc to make sure that any such problems are resolved? I know a lot of people just keep a spare PMD and switch over to it when they experience issues - which seems to rectify the situation.
  19. #19
    I tend to agree with Stanadyne's response, at least in part. Problem is, the design is faulty, in that, it is so sensitive and dependent on the system components mentioned. As common as PMD failure is, it really isn't all that common. Those vehicles that have issues, usually have the issue ongoing, and not limited to the PMD, specifically. I know of several trucks (including one I had, and a bunch of commercial fleets) that still have the OEM driver in place, and happily keep on truckin', with very few, if any, abnormal issues of any kind. I don't know of anyone who complains about their unbroken truck. The trucks I know of that have continuing issues, usually have other issues, almost always among those suggested by the response or related in some way.
    Stanadyne could have designed a more durable driver, but they didn't. Like a lot of engineers, they assume their design will be operated under ideal conditions all the time. Problem is, the real world disagrees, so we are here.
  20. #20
    "In theory, there is no difference between theory and practice. But, in practice, there is." - Jan L. A. van de Snepscheut
    So, as mentioned, a certain number of people carry a spare PMD. Should they be going through and replacing the switches, sensors, connectors, and such? And, if those are the actual problem, why does a new PMD rectify the situation - at least for some period of time?
