Originally Posted by
DmaxMaverick
It was a fun adventure, but yielded nothing of use, other than to confirm that messing with it is a waste of time. Time and money is better spent on a custom chip/program and other proven upgrades, which will offer some real world results.
That pretty much sums up the same conclusion I came to when messing around with the "optic bump." It even messed up my cruise control: it could no longer hold steady RPM when going down hills. Took me a long time to get it back to normal operating parameters. Then the IP failed and I replaced the whole thing anyway.
