Results 1 to 5 of 5
Thread: 85 GMC Sierra Long Bed
    Default 85 GMC Sierra Long Bed
    This is my new to me truck. I go by Jay R.
    Any thoughts on glow plug controller brands?
    Nice truck!
    Wow, with a 2.73 rear axle and 4 speed auto, that rig should be a real fuel mizer. Any idea on what MPG's you're pulling down yet?
    I used to have a square body 3/4 ton with a 6.2L, 4 speed auto, and 4.10 rear axle, and I could pull down 17 - 18 mpg all day long. I can't imagine what you could achieve with a 2.73, although I'm sure it bogs down pretty easy in overdrive.
    Thank you. Yes it is a sloth on hills for sure but it is capable for the light duty homeowner use I had in mind when I was truck shopping. It has a laundry list of issues I am working through so I haven’t driven it too much yet. I did manage to check fuel mileage once so far and it came back at 40mpg. That seems magical and too good to be true. When I get it roadworthy for daily use I plan to check it several more times and get an accurate number over a longer distance and multiple fill ups.
    Yeah, 40 mpg is not realistic. Probably mid to upper 20's will be more likely.
    We owned a 1986 Chevy 2500 Burb 4x4 with the 6.2
    It was near new when we bought it and on a trip to southern California from NW Oregon down I 5 we managed 26 mpg on one leg of the trip.
    Nothing below 20 though.
    22-26 HWY is quite normal if things are in good shape
  1. 2002 sierra duramax 2wd crew 8ft bed for sale
    By liv4vettes in forum TDP Classified ad forum
    Last Post: 01-08-2017, 10:19
  2. Tranny Line Leak - 07 GMC Sierra Classic Allison
    By gimpyhauler in forum 2500HD/3500 HD Trucks & Drivetrain
    Last Post: 05-04-2016, 20:02
  3. 2011 GMC Hd
    By More Power in forum 2500HD/3500 HD Trucks & Drivetrain
    Last Post: 10-13-2010, 15:14
  4. FS: Torklift Superhitch C1203 for Long Bed
    By Axle in forum TDP Classified ad forum
    Last Post: 04-04-2010, 16:40
  5. Cross Bed Aux Tank and Rollcover Together?
    By wheeler in forum 2500HD/3500 Accessories
    Last Post: 12-31-2002, 10:32
