Hi all,
I’m new here and new to the 6.5l diesels.
I purchased a used 2001 Chevy G3500 Cutaway box van about 3 months ago as a work truck. It had 85,000 original miles on it and seems to have been babie. Ran great when I drive it from Montana back to VA and had not given me any issues until last week. I was headed home after work and it just cut off like someone had turned the key off. Never could get it re started and had to be towed home. Once home I checked the obvious things (to me anyways) double checked fuel level, changed fuel filter, checked battery output, checked all fuses, I was getting fuel out of the valve on top of the fuel filter but not to the injectors. Eventually after continual cranking started getting fuel to injectors and it finally restarted but I have no idea what the cause was.
Jump forward a week. Drove it 3 days this week with no problems. Then today it cut out on me 3 times on the way to work. Coasted to the shoulder and restarted. Got to work. Went toleaveto go home and it cranks fine but will not start. Opened a couple of injector lines and there’s not a drop of fuel coming out when trying to start it.
Did some reading and many things pointed to the PMD. Mine already had been replaced at some point with a remote mounted one and was easy to get to so I grabbed a new one at Advance and installed it. Still won’t start. These vans don’t give much room to access the injection pump and fuel shut off solenoid but that’s where I am headed next. Just thought I’d see if anyone had similar issues or suggestions before I throw a bunch of time and money at it.
Thanks for your time and help!
