Results 1 to 2 of 2
Thread: 2008 diesel Duramax diesel
    Feb 2020
    South Jordan utah
    Default 2008 diesel Duramax diesel
    coolant leak I found out it is coming from my engine block heater but it looks like the tightener bolt head is broke off,also that's where the coolant is coming out. any ideas how to get it out.Thank you.
    Hi,Welcome
    This is the forum for the predecessor to the Duramax.
    Don't drive yours anymore,if the bolt head is gone the heater could fall out at any moment.And when it does you will lose all your coolant in seconds.
    Go buy a new block heater and antifreeze with a different vehicle.
    Then replace the old one,if you are lucky you will be able to dig out the old retainer,if you can't it wouldn't really matter because there are thousands of vehicles driving around where it's been left in after a block heater replacement.
  1. Diesel Direct Newsletter - 1/19/10
    By More Power in forum Industry News
    Last Post: 02-21-2010, 17:59
  2. Diesel Direct Newsletter - December
    Last Post: 12-19-2008, 10:07
  3. 2008 Ford 6.4L Powerstroke - an editorial
    By More Power in forum General Diesel
    Last Post: 10-17-2006, 22:36
  4. 8.1 smokes duramax
    By dave p in forum 2500HD/3500 HD Trucks & Drivetrain
    Last Post: 10-16-2002, 11:05
