![Quote](images/misc/quote_icon.png)
Originally Posted by
TheGoose
Fuel tank installed finally. What a PITA.
Replaced all fuel lines up to the injector pump.
We spun the motor over with the gp out to see if we could get fuel to the ip. We disconnected the wire from the ip solenoid. We didn’t think about the oil cooler lines and after about 2-3 attempts had oil all over the floor. We will put a loop in the line today and try again.
You need 12V to the solenoid or it will remain closed
