![Quote](images/misc/quote_icon.png)
Originally Posted by
Vetman7
Hi Jim,
Thanks, I appreciate your reply. I've tried the additives now for about 5k miles, and things are just getting worse (lots of blue smoke and very rough idle). Of course, you'll note from my original post that I've been running a cetane improver since day 1. So clearly that didn't prevent the injector failure issue. Since the injectors were warranty replaced initially by GM, I'll assume they replaced with the same, failure prone type originally used, -which now are also bad!. Since it seems changing injectors is definitely in my future, I'll look for an aftermarket set with better design (any recommendations??). Unfortunately, its a complex enough job that I don't want to do it twice because the cup seals are leaking. Do you recommend replacing all cups with the screw-in style and any idea of the cost? When I pull the injectors, is it obvious if the cups remain intact? Or can they leak even if all appears to be good? Appreciate any additional thoughts...
