Results 1 to 5 of 5
Thread: 1998 suburban 6.2 diesel swap
    Jan 2021
    southeast kansas
    Default 1998 suburban 6.2 diesel swap
    How do I make a 4L60E work in a 98 suburban with a 6.2 diesel?
    You'll need a standalone controller for the electronic transmission - something like this: https://www.painlessperformance.com/wc/66501
    There are other options out there, just that was the first one I turned up.
    Diesel Page Member #2423
    Apr 2009
    Sheridan, Oregon
    Wouldn't a 1998 have a 6.5L and either a 4l80E or 4l60E? Seeing as a 98 would be 'fly by wire', I would say have the ECM flashed or reprogrammed.
    2004 Chevy K3500 CCLB DRW LB7 Duramax. Stock.
    1992 Sea Ray 300DA. 30 plus foot Express Cruiser on a trailer. 13,500# boat and trailer and 69' of combined length rolling. Over length/width permitted load.
    SOLD-95 GMC K2500 SLE 6.5L TD, Relocated PMD to bumper #9 res., Custom Lowes special induction tube, Triple gauges on the pillar EGT, Trans, Boost, High Idle Mod, TCC-Lock up Mod, Custom Back up camera, DIY Manual Wastegate Controller, 4" from down tube to 5" stacks, Vac Pump Removed,2007 wheels, WMI by Cooling Mist 8gph @3psi 11gph on demand
    Dec 2003
    Yukon Canada
    This is an old thread...
    I would assume he was looking at putting it in one that had a gas engine in it
    The 6.5 was never married up to the 4l60E....4L80E was the box used.
    The early 6.2 (1500 trucks) got the 700R4 (4L60) and that was a ticking time bomb.....I tore up several 700R4 behind 6.2's
  1. 1998 Suburban, like new
    By arveetek in forum TDP Classified ad forum
    Last Post: 02-12-2015, 07:18
  2. Holden suburban 1998
    By Stonie in forum TDP Classified ad forum
    Last Post: 07-23-2013, 17:13
  3. 1998 454/nv4500 swap to 6BT Need sources please.
    By drew454u in forum Diesel Conversions & Swaps
    Last Post: 07-13-2010, 16:31
  4. 1998 engine swap
    By zdrepaul in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 10-09-2007, 17:07
