Results 1 to 2 of 2
Thread: DB2 Conversion on ODB2 4x4 with 4L80E Trans
    May 2021
    Reading Pa
    Default DB2 Conversion on ODB2 4x4 with 4L80E Trans
    Alright, This is my first post. I have a 97 2500. These are good trucks but the DS4 pumps are junk. (poor design). I have found little information on the DB2 conversion for us with OBD2. However I don't think there is much of a difference with OBD1 per Bobbie Martins write up. So for the people with OBD2 this should work for us. I will be using a stand alone TCM unless someone here has a different idea. There are many DB2 injection pumps available for sale most diesel shops can build them to 4911 spec. Also you can convert the HMVE 24v to 12v but I think the throttle shaft is different and won't allow a TPS sensor. I am going to try to add a lot of pictures as possible. For me a new truck is out of the question as newer trucks are way over priced, plus there is a lot of aftermarket support for these trucks as well.
    Welcome to TDP
    Yes...This conversion has been done before.....you are on the right trail....
    Yes indeed....Please keep us in the loop/pics
  1. 4 Speed Over.D THM R2(4l80E)4-spd A\trans(MT1)
    By Martin R in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 01-25-2011, 07:02
  2. 4L80E Trans Shutter, ATF+4 Trans Fluid? What BRAND???
    By 97Suburban in forum 1982-2000 C/K Truck & SUV Chassis & Drivetrain
    Last Post: 01-15-2009, 17:41
  3. 6.5 mip conversion with 4l80e auto trans
    By 85-m1028 in forum 1982-2000 C/K Truck & SUV Chassis & Drivetrain
    Last Post: 10-01-2008, 19:56
  4. TCI 4l80e trans controller.
    By rjwest in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 01-18-2004, 16:32
  5. PTO mode and the 4L80E trans
    By jeffreydmet in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 12-08-2003, 18:41
