Turbo shield:
https://quadstartuning.com/collectio...-turbo-blanket
All sorts of cool heat shielding products direct from the manufacturer:
https://www.heatshieldproducts.com/a...o-heat-shields
The A/C dryer cover is factory original. The fuel filter cover is of my own design; it's actually a 12V heater; it's original use was for keeping drain pipes from freezing on RV's; it's a peel-and-stick heat pad that I stuck to a piece of sheet metal that is held on to the filter with a hose clamp. The aftermarket Racor filter housing I'm using did not come with any sort of fuel heater, so I came up with this one.
I would like to go with an intercooler some day. One step at a time!
