Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
Thread: Rebuilt 6.2 Lost Power After 600 Miles
  1. #21
  2. #22
    An injector that is peeing a stream will do it as well.
  3. #23
    These fuel injection pumps are volumetric in fuel delivery (limited by the volume of its pumping plungers per stroke). Sure, they can leak fuel over a longer injection interval (knock, smoke and roughness, like the injector I found in our 6.5) but total fuel delivery per power stroke can't be a lot different than the other fuel injectors.
    The high-pressure-common-rail injection systems like that used in the Duramax/Cummins and others could theoretically turn a leaking fuel injector into a constant ON fire-breathing blowtorch, because fuel delivery isn't volumetric.
  4. #24
    The issue is....If the injector is not spraying a nice clean "cone" of fuel, but instead shooting a pee stream and it is landing right on the Glow plug.....this can destroy the plug and also lead to torched piston crown too..
    I agree on the common rail scenario.....
    Low pop pressure squirts with poor spray patterns can do a lot of damage as well as smoke and be a general nuisance....
    They will however do a fine job of dealing with the "Skeeters"
  1. Lost power?
    By tbeavers in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 06-16-2015, 13:00
  2. Lost power after ran empty
    By waynep in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 12-09-2011, 09:10
  3. Lost power
    By Pogust in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 11-27-2011, 20:29
  4. Lost power...
    By flatbottom in forum Duramax 6600
    Last Post: 02-25-2008, 10:17
  5. Lost Power Assist
    By LandTug in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 01-03-2006, 18:11
