Originally Posted by
Robyn
Break the edges at a 45 degree angle...1/32" wide is all that's needed.
1/32" wide on the holes....Just touch the holes with a standard countersink in an electric drill
The idea is to get rid of the SHARP corners...
You can even do the head bolt holes in the block deck....Any bolt hole that has a sharp edge.
Just break the stress riser....
Will this solve all the ills...NOPE...But it will not hurt a thing.
If you use a 1/32" ball bur in your dumore and carefully remove the sharp root in the block cut where the main caps sit "L" This L is the cut....make it so the corner is slightly round...and run the roundness off the edges.....Do not modify the actual register...The cap must be tight....
A crack in this corner is not repairable
