The Skirts look pretty good.
IF IT WERE MINE.
I would make sure there are no foreign objects jammed into the piston anywhere...Clean up the little beast with some 400 wet/dry paper using some diesel on it.
Make sure the piston is smooth with no ridges sticking up.....Wash well and put it back on the rod.
Make sure the new rings fit easily with no tight spots in the grooves.....
Put the end gaps at 90 degrees from the fire chamber in the piston and the top and second ring gaps 180 degrees apart to give the best chance to hold compression well.
Take the bottle brush hone to the bore and smooth it up keeping the tool moving up and down at a fair pace.
AS I SAID BEFORE.....COVER THE CRANK...WELL...
Use some lube like WD 40 ON THE HONE....
Get a decent cross hatch...make sure there are no high ridges from any of the scratches.
Wipe clean....lube up and stuff that bad boy back together.....
CAUTION....Be sure to BLEED ON IT A LITTLE
GOOD TO GO...
Just to clarify.....This is not AAA+++ Practices....but I think she will run pretty good....
Not sure what the rings listed at ebay were.....find a set of military chrome rings.
The top ring in your piccy looks like a moly filled ring ....these do not handle crap at all...
There is a moly filled center and a little band top and bottom that is cast iron.
The moly gets trashed by the crud and there goes the seal.
Moly rings require a very smooth finish.....
Chrome rings will wear well and deal much better with the less than perfect surface.
The slight imperfections will fill in with carbon over time and should be pretty good...
I have put together worse in a pinch and ran it for years.....
They used chrome rings in the HMMWV so the sand in the desert would not knock out the rings so easy.....At least that is what some of the fellas I have talked to that were in the sand box said.
I have some military packaged rings that are chrome...but they are .020 OS
Just a thought 60G glow plugs on a 12 volt system.....
Give it a go......The bleeding portion is very important
