I'm getting ready to replace my original harmonic balancer with a Fluidampr unit. Is it recommended to replace the harmonic balancer bolt at the same time or can it be used more than once?
Bob
'83 K2500, 6.2L J-code, NV4500, NP208, 3.73 gears
The bolt can be used more than once, and is most often. If yours is original, I would probably replace it, but if it looks good, just as probably reuse it if it's too much hassle. Toss a coin, if necessary.
Sounds good. Thank you.
I would caution against using the bolt to pull the damper onto the crankshaft. It could strip the threads in the crank snout. Instead, use a crankshaft damper installer like this one, which you can make. You will need a short length of steel pipe to use as a spacer.
Contact Me
Content Web Site
Duramax Diesel Service Guide - How to Replace Head Gaskets, Injectors, Water pump, and more
Photo Album
TDP Youtube Channel - New!
