Results 1 to 2 of 2
Thread: Head Gasket
    Mar 2023
    USA Missouri Eureka
    Default Head Gasket
    [COLOR=#1D1D1D][FONT=&quot]Newbie here. My truck just blew a head gasket
    1995 k3500 6.5 F TD Dully. New Optimizer build 2/28/25. New IP 5521. New GM8 turbo. New fuel tank,lines and LP. OPS hose upgrade (Leroy,s). New complete AC system. K&N open air filter. Diamond 4” turbo back exhaust. 2.5” crossover.New AC delco GP,s. Relocated PMD kit(front bumper) from Leroy,s
    Leroy,s LP harness. Relocated AC Delco FFM canister w/ stainless braided fuel hoses. High flow water pump and new hoses.
    Dec 2003
    Yukon Canada
    If you are going to keep the truck for a while buy the Diesel Page books on your truck loaded with great info for keeping it alive.
    Do both head gaskets while you are at it.
    Be prepared to start looking for replacement heads,there is probably no chance they aren't cracked.
    If you have the ability to pull the motor to do the work on it,it's almost easier. Especially if you are working by yourself.
    I had to pull the motor from my Sub as it had a bad piston from a piece of the exhaust valve broke off and beat up the piston and head pretty good.
  1. head gasket?
    By wookienelson in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 08-23-2010, 15:44
  2. Blown Head Gasket ? Cracked head ?
    By sailun in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 01-16-2010, 21:44
  3. Head Gasket or Cracked Head or ??
    By LTChip in forum 2500HD/3500 HD Trucks & Drivetrain
    Last Post: 09-14-2005, 13:24
  4. Do I need a head gasket?
    By AlanL in forum Duramax 6600
    Last Post: 10-07-2003, 11:34
