After lots of searching I found a list of OBD1 ABS codes, what I found is code 25 is L front speed sensor or circuit open. 26 is missing L front speed signal. 37 is erratic rear speed signal. these codes are supposedly for a 1995 chevy truck. Do these make sense DmaxMaverick? I got the codes by jumping the second from left lower terminal to the upper right terminal on the test port.
1995 K3500 Silverado extended cab dually auto trans. Diamond Eye exhaust, KOJO chip, manual boost control, HD cooling, PMD behind bumper, modified fan clutch.
