Page 1 of 2 12 LastLast
Results 1 to 20 of 29
Thread: Lift Pump power 94 3500HD ?
    Dec 2003
    Yukon Canada
    Default Lift Pump power 94 3500HD ?
    Hi All
    I am bringing a 94 3500HD back to life...
    Have zero history on the truck,it was unwanted and i had space in my yard.Had a rebuilt engine installed and a decent dump box so i saw value.
    Got it running by supplying the lift pump with it's own power source.Starts and runs good while the battery is hooked to the lift pump.
    In checking the wiring to the lift pump,i got power at the pump but no ground.
    It has the old relay on the firewall for the lift pump which i tried a couple others.I tried to find the ground in the relay wires that went to the pump with no luck.
    Then it was the end of the day.
    Does anyone know where the ground for the pump comes from? my guess is the OPS fits in somewhere.
    I did not check for ground as it was running.
    Thanks Thomas
    Dec 2003
    Yukon Canada
    Hi All
    So i did check the leads for the lift pump while it was running yesterday.
    No ground while it's running,also no Positive while running.I was able to get positive power yesterday by jumping terminals on the plug for the relay.
    Checked the fuel pump fuse on the fire wall no positive power there,or ground either.
    Truck runs great while idling,no smoke on start up or while idling.
    Then when i went to start it again it would not fire off,checked the shut off solenoid and it has power and is clicking.
    It was time to head home so i put my stuff away and called it a day.
    Dec 2003
    Yukon Canada
    I finished off my winter job on Saturday,no more delivering heating fuel for at least the summer.
    Today i get to try and make the 3500HD run again.
    I will plug it in to warm the engine again and see if it will start.
    If it still doesn't i will try a different FMD.
    One step forward and two back.
    Dec 2003
    Yukon Canada
    Plugged in the truck and put the charger on the batteries
    Hooked both batteries in tandem with my towtruck and two sets of booster cables and the 3500 started again with the lift pump on it's own power source.
    While it was running i disconnected the power from the lift pump and there was no notable change in the engine while it was idling.It also revved with zero issues with the lift pump disconnected.
    But it did not want to start again after sitting for about an hour.
    I think it's the crap batteries i have in the 3500.And if they haven't been charged i believe they just drain the power down below the minimum required for the computer.
    Knoxville,Tennessee
    The 6.5 takes two strong batteries. My 94 left me stranded once with what felt and sounded like good batteries. Wouldn't even jump start. Two new batteries and it started right up. IIRC the 6.5 has to reach 200 rpm cranking before thew computer will call for fuel
    -Patrick Henry
    A5150nut
    2006 K3500 D/A
    94 6.5 4x4 5spd Sold
    The 6.5 needs about 200 RPM's cranking speed, but I don't think the PCM requires it. If the starting system is so loaded it can't reach ~200 RPM's, by whatever means, it's very likely the 12V system load is dropping the available voltage below what's required to fire the injector driver. I recall a while back, a "newer" driver (Sol-D?) had starting issues if/when the line voltage dropped near 9-10V. I think other drivers are not as sensitive, but probably not far off. Weak batteries, even if able to crank fast with an otherwise healthy starting system, may not be able to maintain battery voltage enough to fire the drivers.
    Trying to start without a working lift pump may cause other issues. If the IP is weak, it may not be able to develop pop pressure at lower cranking RPM's. A weak IP and the absense of supply pressure makes for a hard-starter or a non-starter under the best of conditions.
    Dec 2003
    Yukon Canada
    I have had the lift pump on it's own power source since the first start.The engine sound doesn't change once the lift pump is removed from the power source.
    The no start for me was/has happened twice.
    Today it's not raining so i will try a couple things to narrow the no start down.I am going to take the almost new set of batteries from my tow truck and install them in the 3500HD and see if that solves the no start.
    Then it's just finding out why there is no negative in the lift pump connection.
    Dec 2003
    Yukon Canada
    Yesterday with good batteries it started OK the glow-plugs didn't cycle normally so i kept cycling the switch.
    Idels good with or without the lift pump.
    It will start right away once it's up to operating temp,if you shut it off and start it right away.If it sits for 30 miniutes it will not start till it's cooled down.
    Tried cooling the PMD with snow which didn't help,it wouldn't start till the engine cooled for a while.Also tried to cool it with propane the next time for a more immediate cooling of the PMD. Nothing.
    While it was running i checked the connector for the lift pump and it had no power.
    Any ideas on what could be the cause of the no start while warm?
    Or the no power to lift pump?
    Could they two symptoms be from a common failure?
    Thanks
    They don't sound related. You'll need a diagram to trace back the LP ground. If it simply grounds to chassis, that's simple enough to remedy locally (just ground the harness wherever it's convenient or practical). If it's switched, you'll need to know where. The 94 LP relies on the OPS for Batt+ while running (it should be relayed or failure becomes more frequent).
    The no-start after semi-cool isn't uncommon. Some remedies include manual GP cycling (add a momentary switch and relay), or hacking the PCM temp sensor (resistor to lower the perceived temp). Next time it doesn't start after a partial cool-down, disconnect the temp sensor before key-on (PCM will see -40). That should force a maximum GP cycle. If it glows and starts, there's your problem. Also, verify all the GP's are actually glowing when power is applied. If a few are MIA, it can cause starting issues in the gray areas.
    Starting and idling w/o a working LP isn't unusual, if the fuel system and IP is otherwise healthy. It will fall flat under load, though.
    Dec 2003
    Yukon Canada
    Yesterday
    Started the truck not plugged in with good batteries everything worked good,temps were above freezing when i started it.Got to -6 C overnight.
    Idled it for 1/2 hour or so,disconnected the battery from the lift pump and took it for a short drive.Basically a wide open throttle romp to see what happened.
    Good power for a 6.5 in a HD truck no excessive smoke,no hesitation.
    Parked it,shut it off and it fires right up.Left it for an hour,no start.Two hours no start.
    I did try disconnecting the temp sensor on the thermostat crossover,no start.I did the continuity check on 6 plugs,but didn't remove them for the ultimate check.
    There is no function on the relay for the fuel pump when the key is on,and no power at the fuse for the fuel pump.Both the fuse and relay are on the firewall.I did check to see if power will get to the lift pump by jumping the relay plug and the wire is good to the pump from the relay.
    No SES lights at all.
    Knoxville,Tennessee
    IIRC relay powers lift pump for 10 seconds then switches to Oil pressure to keep it activated. So not to pump fuel when upside down, strapped in the seat and can't get away.
    -Patrick Henry
    A5150nut
    2006 K3500 D/A
    Dec 2003
    Yukon Canada
    Yesterday kept me away from the truck
    The day before...
    Set up a oil pressure sensor with it's own pressure source to see if it would have any difference.
    I found that triggering the purple wire on the solenoid would get power to the lift pump, same as keeping pressure on the OPS.With the both OPS unplugged from the system the gauges do weird things while running.The temp gauge will follow engine RPM's.
    Still no ground at the lift pump.
    Still refuses to start after sitting for about 15 minutes at operating temp.Unplugging the temp sensor changes nothing.
    Going to have to find a wiring diagram somewhere.
    And i think i need an extension harness and remote mount for the PMD and another PMD to rule out the one on the pump being the culprit on warm starts.
    I will rob the one off my burb and see if that cures anything.
    I feel the injection pump is OK as it will start and drive without a lift pump, and there is never ant indication when the lift pump is powered down.
    Back to basics. This is a chassis ground failure. It sounds like you have the systems making their own grounds, through other components. It doesn't take long before really bad things happen. Make sure both batteries are grounding to chassis, and every other ground point (engine, frame, body, etc.).
    Dec 2003
    Yukon Canada
    Good point...
  15. #15
    Rule #17: when two or more seemingly unrelated systems start interacting, check your grounds.
  16. #16
    Dec 2003
    Yukon Canada
    The normal grounds are no an issue anymore.
    Cleaned them all up and added a couple.
    There were 3 wires to the right rear manifold,added one to the right battery
    Added one to the left which went to the frame
    Nothing changed...
    Should have remembered to attack them as soon as i found no ground at the lift pump.
    When the truck is running there is nothing at the lift pump,no ground or positive.
    I can trigger the fuel pump relay with power to the purple wire and get power to the lift pump.
    Still will not start when it warm soaks after 15 minutes
    Starts cold with or without the lift pump.
    Maybe today i will have time to rob the extension harness and cooler from my Burb to rule out the PMD as the hot soak issue.
  17. #17
    Dec 2003
    Yukon Canada
    Hi All The saga continues
    Yesterday i robbed the spare PMD on a cooler and extension from the Burb
    The pmd is defiantly not the component that doesn't work after a heat soak.
    Once at operating temp with both PMD's it will start if you shut it off and re start right away.Leave it sit for 15 minutes and nothing with either PMD.Unplugging the temp sensor makes no difference.
    Wait 2 hours and 15 minutes and it fires right up with either PMD
    What else could heat soak and not allow the truck to start?
    Still no power or ground to the lift pump.When i use the second oil pressure sensor hooked to regulated air 20psi with oil in the fittings and OPS the lift pump will get power.Plus if i trigger the purple wire on the fuel pump relay it supplies power to the lift pump.This sensor max's out the oil pressure gauge even at low regulated pressures.
    I am sure i could do some creative wiring to power the lift pump, but would rather fix whats stock.
    Thanks for all the tips and directions to check so far.
    Fingers crossed i find an issue to correct it.
  18. #18
    Back to the grounds. Batteries to frame and engine are important, but the entire chassis needs to be interconnected. It should have a large, bare bonding strap from a head or intake manifold to the firewall. This is very important to provide a ground to the cab and interior, including instrumentation, HVAC, ignition, and lighting. It should also have a bonding strap between the cab and/or frame and the bed (OEM or otherwise).
    Have you confirmed operation of the OPS?
    When you have a warm/hot soak no-start condition, have you tried to manually cycle the glow plugs? Many of the 6.5's won't start well without GP's when not at full operating temp. Is the WTS/GP lamp coming on during this time? If so, how long?
    A tired IP is the next suspect, despite the cold water test results.
  19. #19
    Dec 2003
    Yukon Canada
    I added grounds and cleaned all points in the engine bay.Left battery ground large ground going to the engine then i added a large ground from battery to frame Right battery large ground to battery to engine, small ground to fender i added another small ground to the back stud on the manifold which had 3 wires going to it.Cleaned all points and soldered all rings to wires.I have a dead 94 in the back yard i compared the grounds to and i think they are all accounted for.Have robbed the fuel relay from it.
    With the original OPS the gauge reads while it's running,but no power to the lift pump.
    With the OPS and regulated 20 lbs pressure rig the lift pump gets power but the gauge pegs out to max.
    I don't remember reading that there are different OPS,I will try a third one from a 94
    In the warm/hot soak mode the glow plug light cycles normally
    The IP is ok i believe as it will start and run, and drives wide open throttle with no hesitation.
    When you shut it down at operating temp and restart right away the glow plugs cycle and it fires right up with or without the lift pump.
    Nothing changes with or without the coolant sensor plugged in, and when changing PMD's
    It's like there is a switch off once it's warm soaked.
    Have been by myself which limits some tests.Going to try and rule out the fuel shut off with some help.I tried to remove it last week but was unable to that try.It has a recessed allen fitting instead of the nut on top .It was getting power when it doesn't start,maybe it's the culprit
    I am assuming the IP was installed new with the new engine it had paint marks on the connections to the PMD and other points. It has a green tag on it which i think i read is the 94 IP.
    Yesterday i spent no time on it,had another project.
  20. #20
    The same OPS is used for 1992 - 2002, all models. It is dual function, a sender for the oil pressure gage, and a switch for powering the fuel lift pump. If both functions work, but only one at a time, the OPS is bad. The gage pegging when the lift pump gets power is an indicator. The two functions are independent, and only share the ground. If one function effects the other, the switch is failed. All this assuming the remaining associated electrical is correct. If you're still having power/ground issues, bets are off.
  1. Lift pump no power
    By Unboy2000 in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 05-18-2010, 02:37
  2. Lift Pump wires no power
    By xtrempickup in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 12-25-2007, 07:53
  3. No wait to start light and no lift pump power
    By dufrain in forum 6.2L/6.5L Diesel - Upgrades & Service Questions Answered
    Last Post: 08-21-2007, 07:27
  4. no power to lift pump
    By oliver Ben in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 05-14-2007, 19:01
  5. rewire lift pump power
    By Shad in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 02-18-2004, 04:26
