Results 1 to 5 of 5
Thread: Dash removal on a 06 Silverado 3500
    Dec 2005
    Klamath falls/keno Oregon
    Default Dash removal on a 06 Silverado 3500
    Trying to replace the radio antenna cable, I have the grommet on the cable removed
    But the the cable is at such an angle it won’t come out.
    Hummer wheels :^)
    dual lift pump
    Banks air intake
    429,000 miles and counting..
    Dec 2005
    I would like to have a talk with the designer on the radio system...
    but what I have found is a few youtube videos by the same guy pulling his dash cover,
    looks to be a job anyone with a sailors vocabulary can do here's one of the links:
    https://www.youtube.com/watch?v=xXs9uECjsuk
    Hummer wheels :^)
    dual lift pump
    Banks air intake
    I was a sailor once...
    On the early 2000s, the top skin of the dash can be removed. I did that while installing the new (at the time) 2001 dash in my 1989 Chevy K1500. I don't remember too many of the details, other than I have a few pics of that endeavor.
    Dec 2005
    it turned out to be an easy removable job..I didnt follow all the steps in the video. just the dash bezel and pillar posts need to be removed before removing the 6-7
    screws holding the dash cover.
    Hummer wheels :^)
    dual lift pump
    Banks air intake
    It seems that automotive design (all brands) has been shifting away from serviceability for quite some time. Nowadays, more mechanics are lifting the cabs when these diesel engines need serious work, and what should be simple tasks require major disassembly to get to the part. I watched a video a week or so ago about a simple sensor replacement on a Dodge Ram gas engine, that had an 8 hour shop time associated with it. Over a hundred bolts/nuts/screws and a truck bed full of panels had to be R&R'ed.
  1. Windshield Wiper Arm Removal 2004 HD Silverado
    By Noface in forum 2500HD/3500 HD Trucks & Drivetrain
    Last Post: 03-25-2009, 17:57
  2. 1995 Silverado Heater box mode valve removal
    By banjoron in forum 1982-2000 C/K Truck & SUV Chassis & Drivetrain
    Last Post: 07-31-2007, 17:38
  3. Dash Problem 92 Silverado 2500
    By William Guenzler in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 03-11-2004, 09:42
  4. Dash Problem 92 Silverado 2500
    By William Guenzler in forum 1982-2000 C/K Truck & SUV Chassis & Drivetrain
  5. Dash Problem 92 Silverado 2500
    By William Guenzler in forum 2500HD/3500 HD Trucks & Drivetrain
    Last Post: 02-21-2004, 12:53
