Page 2 of 2 FirstFirst 12
Results 21 to 29 of 29
Thread: No overdrive after injection pump swap
  1. #21
    Jun 2023
    Ottawa valley
    The ground on the back of the motor is in good shape..and voltage leaving the fuse box to the transmission is good. I’ll test the batteries as soon as I can.
  2. #22
    Quote Originally Posted by Tatlocktim View Post
    All he did was unplug the linkage from the injector pump to the black module on the fire wall and made sure all linkages connected to transmission were attached properly
    When you say "linkage" do you mean "wiring harness"? If so, the problem probably was a bad or dirty connection, and, hopefully, it's fixed. Might be a good idea to put some dielectric grease on those connectors to help prevent future degradation.
  3. #23
    Electrical connections ?????
    Be a good idea to spray the connections with electrical connector cleaner and reinstalling.
    Even some dielectric grease is not a bad idea.
  4. #24
    Haaaaa...We posted 3 minutes apart.....Same ideas too..
  5. #25
    Ya gotta be fast!
  6. #26
    This stuff likely due to being handled recently by the guys at the shop...
    Hey Tim
    You folks use salt on the roads up there ?????
    That is a killer on connections....and metal too
  7. #27
    Jun 2023
    Ottawa valley
    I think we are the salt capital of the world
  8. #28
    Salt / moisture laden air gets into everything.....Even electrical connectors such as "Weather pack" and "Metripack" connectors.
    Use of the spray contact cleaner is a good thing....And as mentioned DIELECTRIC GREASE
    Keeping electrical connections working in the salt belt can be a challenge.....
    Best thing....We now know the source of the issues at this time....
    Treat anything that has been touched recently.....I would advise against messing with anything else that is working correctly......IF IT AIN'T BROKE DON'T FIX IT....
  9. #29
    The TCM, other than throttle position (TPS), also needs a few other signals to allow the 4L80-E to operate normally....
    1- Engine speed (ESS).
    2- Vehicle speed (VSS).
    The 4L80-E conversion I incorporated in our 1989 6.5TD Power Project truck also needed a couple of speed sensors mounted to the transmission directly (trans input speed and clutch pack output speed, iirc). Don't remember exactly what was being measured here... other than a means to sense slippage. I think there's also a transmission temperature sensor.
  1. Injection pump swap.
    By 6.542762mw in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 01-11-2006, 17:16
  2. NEW ENGINE AND PUMP INSTALLED.PUM IS losing injection pump prime, is THIS A bad PUMP?
    By asabadin in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 03-04-2005, 06:37
  3. New Injection pump
    By wvo in forum 6.2L/6.5L Diesel - Upgrades & Service Questions Answered
    Last Post: 02-08-2005, 16:23
  4. Injection pump warranty- metal shavings from lift pump??
    By busman in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 12-29-2004, 19:14
  5. injection pump
    By FLHRI in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 05-21-2004, 06:39
