Results 1 to 4 of 4
Thread: 6.5L Cylinder mismatched casting
    Aug 2023
    United States, Oregon
    Default 6.5L Cylinder mismatched casting
    Hello,
    I apologize if this topic has already been covered. I performed a search for cylinder heads and combed through pages of post but couldn't find an answer to this question.
    1.) Can you put mismatched casting numbers on an engine?
    2.) Can you put mismatched injector angle heads on an engine?
    Hi
    You probably can but i would not mix stuff, the engine will not be as balanced as it should be.
    It would be a get home type of fix which may not make the home part
    The heads came in several styles
    The C engine (1/2 ton) with more emission
    The J engine (3/4 and 1 ton stuff
    There are a bunch of different pre-cup designs.....DO NOT MIX AND MATCH THESE AT ALL.
    Run all matching pre-cups.
    Best to keep matching heads with matching cups.
    The injector angles came into play when the turbo came into the game....Make more room to clear the turbo and such
    Short injectors or long injectors.....Fine or coarse thread injectors (Coarse thread...Early 6.2)
    In a pinch, you probably could use a mismatched set, but as others here suggest, it could result in a more unbalanced running engine. Personally, I'd not consider it unless the valve diameters and the pre-cups were the same (or had the same size openings).
  1. Casting #
    By Motor sarge in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 05-16-2014, 11:51
  2. Casting # Help
    By w6bauer in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 02-05-2013, 11:27
  3. Mismatched 6.2 Precups
    By WeaselWerks in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 11-16-2006, 12:11
  4. casting # ?
    By dieseldummy in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 05-24-2006, 21:57
  5. Block casting #'s
    By smcghan in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 10-23-2004, 22:14
