Results 1 to 10 of 10
Thread: P003A code
    Dec 2005
    Klamath falls/keno Oregon
    Default P003A code
    did a search didn't find anything to work with..
    links, thoughts? I know its turbo related...is it something I can do?
    Hummer wheels :^)
    dual lift pump
    Banks air intake
    429,000 miles and counting..
    According to my research, the vanes and/or unison ring aren't able to move their full range. It or they could be fouled/dirty/broken, or it could be a solenoid issue. I'd start with cleaning the solenoid contacts, and checking the harness for any damage (easiest to access, I'd imagine). What remains in internal to the turbo.
    Dec 2005
    WOW a new sensor is between $35 to over $500..hope cleaning it works
    Hummer wheels :^)
    dual lift pump
    Banks air intake
    Good luck!
    Dec 2005
    I ordered a new one, I have 425k on the truck...
    Hummer wheels :^)
    dual lift pump
    Banks air intake
    What did you order? $35? $500? Something else?
    I understand the 425K miles. Not really much to complain about.
    Dec 2005
    I ordered the cheap one..10 days to get to me so this morning Ill take the oem sensor out and clean it to get
    a few more miles out of it....*update*..I pulled the original and all looked ok, the "plunger" was free floating...
    I hit it with some cleaner anyway...I dont think thats the problem, but the new one is 9 days away..
    found this link and it didn't make me feel any better...possible turbo replacement...the one in the truck now
    is a rebuilt....
    any thoughts on another rebuilt turbo?? sources? I have 425,000 miles on the truck..
    https://www.schultzdieselsports.com/...duramax-trucks
    Hummer wheels :^)
    dual lift pump
    Banks air intake
    Dec 2005
    the new sensor has a more harder to depress spring than the OEM..
    Hummer wheels :^)
    dual lift pump
    Banks air intake
    Is that a good thing? Was the OEM sensor just tired? Did it fix anything? Do extraterrestrials really like peanut butter candy? Inquiring minds want to know.
    Dec 2003
    Yukon Canada
    I like peanut butter candy...
    And have been told that i am way out there
  1. Need help with P003A & P2563 codes
    By skevac in forum Duramax 6600
    Last Post: 07-28-2016, 07:40
  2. p2563 & P003a code's
    By spongebob in forum Duramax 6600
    Last Post: 07-27-2016, 13:47
  3. Replies: 1
    Last Post: 07-02-2010, 09:15
  4. WTB - code reader/code tool for a 89-91 GM with the 6.2L?
    By AJMBLAZER in forum TDP Classified ad forum
    Last Post: 09-21-2009, 18:44
  5. Code 29 Glow Plug Relay Fault, Code 35, 36 and 83
    By chris_maxwell in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 12-31-2003, 11:42
