Here are the GM part numbers for some items that may be very useful.
Some parts guys can't seem to find this stuff.
The filter bypass is #25014006
Cooler bypass is #25161285
The plug for the Cooler bypass bore (goes on top and has the little hole) is #14066310
Drive this plug down until it bottoms in the bore so that the filter adapter locating tab will not bottom on the plug
The late squirt nozzles are a #12561141 (small ones)
The little oil pump drive shaft plastic connector that goes at the
pump and keeps the shaft in is a #477249
Cylinder head dowel sleaves (GM calls them dowel pins) #12558081
Rocker arm retainer buttons are a #23500076
The metric bell housing bolts for late blocks uses a #15724226 bolt that has a metric stud top
The new style crank dowel pin that goes in the flex plate end is a
#10046031
This is a roll pin type and drives into the crank.
This is a needed item when using a Scat crank, as they dont come with anything.
Oil pump drive/vacuum pump gasket
Part #14022649
The major parts houses do not service these
List price is $1 and if you get a shop discount they are 75 cents each
Ebay sellers offering them at $6 each
Missy
