Thread: Injector Pump failure symptoms?
    Jan 2020
    Trabuco Canyon, CA.
    Default Injector Pump failure symptoms?
    My '94 K2500 342K miles, usually fires right up. Batteries are due but I've kept them on a maintainer. Fuel filter likely due for replacement. Check Engine light flashed randomly a few times last week. Today typical start up:Glow plug light came and went, fuel pump working; ran rough for about 10 seconds and stalled. Will not run. I've never replaced IP. So, what are IP failure symptoms? Other possibilities? Thanks in Advance!
    '94 K2500, '82 VW Veggie Cady (sold), Standby: '99 E-350 gasser, Racer: 1964 Front Engine Dragster on E-85.
    It sounds more like air, or an obstructed/stopped fuel supply system, for whatever reason. A noisy fuel lift pump does not mean it's moving fuel, or that fuel is going where it should. Start with a fresh fuel filter and priming, and treat it as though it's air-locked (probably is, or will be).
    An IP failure is usually gradual, over hours, days, weeks, or months, with more profound symptoms. If it started normally and ran, for however long, the IP and GP systems are more than likely OK.
    Don't rule out shenanigans, if the truck is accessible to strangers, or rodents/pests.
    Jan 2020
    Trabuco Canyon, CA.
    Thank You. Just as you suggested, fuel filter and purge did the trick. Much appreciated.
    My pleasure.
  1. Injection Pump Failure Symptoms?
    By Ms54Coupe in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 12-17-2010, 13:31
  2. Injector Symptoms
    By DmaxMad in forum Duramax 6600
    Last Post: 01-16-2009, 06:11
  3. Replies: 5
    Last Post: 08-02-2006, 15:10
  4. Injector pump failure
    By duramaxdrvr01 in forum Duramax 6600
    Last Post: 07-31-2005, 16:47
  5. Injector Pump failure: part two
    Last Post: 07-31-2005, 12:11
