After nearly 20 years and many thousands of miles of trouble-free service, the thermal actuator quit on the front axle of my Tahoe. This is the electrical device that disconnects the passenger side axle shaft from the differential. This prevents the front driveshaft from turning when in 2WD, saving wear and tear and improving MPG.
I was on a 4x4 trip in October, and at the end of one of the trail rides, I noticed the 4x4 light on the floor shifter was no longer illuminated. This light normally turns on when the front axle is engaged. I did some trouble shooting, and verified that the front actuator was no longer working, so no more 4WD!
The most common solution is to upgrade to the newer electric actuator instead of replacing the original thermal actuator. The electric version is faster and more reliable, but it does require some wiring modifications, including running a new wire from a 12V + ignition source. I seriously considered this option, but I decided to go another route, and install the fully-mechanical 4x4 Posi-Lok:
https://4x4posi-lok.com/product/psl600-4x4-posi-lok/
This replaces the electric/thermal actuator with a mechanical version that is operated by a push/pull cable mounted in the cab. For me, there were two advantages with this option - 1. No more having to rely on anything electrical or electronic; even with the more reliable electric actuator installed, it would still require an electrical signal from the floor-mounted shifter to tell the actuator to engage. 2. The Posi-Lok will stay engaged, even with the ignition turned off; this is an upgrade in safety when using 4WD and parked on an incline; with the electric/thermal actuator, the front axle could disengage when the engine is turned off, causing a loss of traction when parked off-road, when winching, etc.
The install was actually easier than expected, and even moving slowly due to a recent minor surgery, I was able to complete the project start to finish in about 2 hours. It works great, and is simple to use.
New actuator installed:
Push/pull cable mounted beneath dash:
2WD position:
4WD position:
4WD indicator still works on floor shifter:
Back on the trail again:
I am really pleased with the product, and feel like I have a very reliable 4x4 that will work every single time I need it.
As a side note, if you ever find yourself in an emergency situation and your actuator won't engage, just grab a 3/4" impact socket. Remove the original actuator, toss the 3/4" socket into the axle, and then reinstall the actuator. This will cause the actuator to push on the lever inside the axle and engage the front axle permanently, and makes it just like a Jeep Wrangler - as soon as you pull the transfer case into 4WD, you're ready to go! The front driveshaft will spin at all times, though. I actually did this for a few weeks while I contemplated what I wanted to do. However, I could tell my front driveshaft was not perfectly balanced, and I could feel it vibrating, especially at interstate speeds. You can actually buy a "PermaLok" that does this exact thing, but there's no need to spend over a $100 when a perfectly good socket does the job! I decided I wanted to be able to have a front axle disconnect after all.
