Results 1 to 5 of 5
Thread: Heater Core & Evaporator Replacement
    Default Heater Core & Evaporator Replacement
    Here's how I spent my week off work during Christmas break: replacing the heater core and evaporator on my 1995 Tahoe 2 Door Tahoe!
    Whew, what a job.
    I had an A/C refrigerant leak I couldn't pin down, and I also had not been happy with the air flow out of my dash vents for quite some time (always felt like there should have have been a lot more air movement coming out the vents). I decided after 419K miles, it was time to replace the original heater core, evaporator, and condenser (A/C compressor is fairly new).
    I removed the entire dash assembly, and then the HVAC box:
    HVAC box removed:
    The original evaporator was packed full of nearly 30 years' worth of dirt and debris:
    And upon disassembling the HVAC box, I discovered that all three main blend/mode doors were in terrible shape; most of the rubber sealing flaps were completely gone:
    Here's a comparison of one of the old doors against the new door. You can clearly see how the new door has a rubber flap all the way around that the old door no longer has:
    New heater core and condenser (forgot to grab a pic of the new evaporator):
    New condenser going in:
    I also replaced the hard line going from the evaporator to the condenser, and of course a new drier.
    I also took the time to replace all three electric actuators that open and close all the blend/mode doors.
    While I wasn't looking forward to this job, all in all, it really wasn't all that bad. I took my time and was not in a hurry, so I didn't feel stressed about how long my rig would be off the road. I started the day after Christmas, and finished up this past Saturday after New Year's; and that included taking 3 days off for a mini-vacation with my wife!
    I still need to vacuum and recharge the A/C system, but everything is else is back together and working properly.
    With a new, clean evaporator and new blend/mode doors, there is much improvement in the amount of air moving through the dash vents.
    Dec 2005
    Klamath falls/keno Oregon
    WOW..hope that cures the "leak", from the looks of the coils I can see why you didn't have all the air flow..
    Hummer wheels :^)
    dual lift pump
    Banks air intake
    429,000 miles and counting..
    Feb 2006
    I did this same job on my '93 C2500 6.5 a few years ago. I didn't have the luxury of plenty of time. It was_the_job_from_Hell. If I ever had it to do again, I'd finally sell that old truck. My best advice, take plenty of pictures while you're disassembling things.
    Quote Originally Posted by 56pan View Post
    ....My best advice, take plenty of pictures while you're disassembling things.
    Indeed! I forgot to take any pictures of the blend/mode door actuator linkages. I disassembled the whole HVAC box and then ordered the replacement doors. It was a few days before I got back to it, and I couldn't remember how all the linkages went together. Thankfully I found a picture on the good old Google and was able to get it back together.
  1. Heater Core Replacement in Chevy Van
    By Bruzersdad in forum 6.2L/6.5L Diesel - Upgrades & Service Questions Answered
    Last Post: 01-22-2007, 02:26
  2. heater core replacement
    By meanchev in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 10-08-2005, 08:51
  3. air conditioner evaporator core replacement
    By wjm in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 08-26-2005, 01:45
