I had to move my fuel tanks back on my t6500 and I ripped open one of the fuel lines. Stupid, I know...The truck had been running perfectly before then. I fixed it with new stuff and got it back together and now it wont start. I did some troubleshooting and the lift pump works when jumped off. as far as I know, there is only one lift pump on the right frame rail just by the right side tank. But I pulled the fuel line as it goes into the engine, and there is no fuel there. zero fuel pressure. It seems on a diesel, no fuel to the fuel rail, and no start, they don't suck fuel very well...Am I missing something? is there another lift pump or something?
Another thing I noticed was the pressure from the right tank goes to a t fitting where one line goes to the left tank, and the other line goes to the return to the right tank. bizarre. maybe this is a last stop measure in case the right fuel pump runs incorrectly?
I took out the sending unit on the left tank, and there are just steel lines that run to the bottom of the tank, so jumping the right side fuel pump did nothing...
there must be another lift pump, I am totally baffled...does the high pressure pump suck fuel thru the fuel filter and up to the engine?
