I replaced mine with a genuine GM brand. The Fluidamper model is nice, but boy is it expensive!
Definitely a good idea to check the condition of the balancer; if there's any cracked, missing, or bulging rubber, I would definitely replace. The rubber damper pulley also needs inspected for the same reasons. When it fails, it can make an awful noise as well. But when the harmonic balancer fails, it can take out the engine!
