Originally Posted by
JetBoater
The shop usually does all 6 outer bolt holes on the inner 3 main webs. They do this even if they are not cracked as a preventative measure. This is not cheap... at $100 per hole.
They finish off with align honing to ensure everything rotates straight.
I will be building the engine and selling it to recoup some of my $,$$$. I am happy to provide any info to those who are in need of this type of repair... I am a believer
The product is a LOCK-N-STITCH product and the inserts are called Full-Torque... apparently well known in the cast iron repair field.
Caution: you can possess the right product to fix a crack, but you still require a skilled shop to ensure you end up with a stable repair.
My shop charged me $40 per bolt hole to do this fix. But, it was only the second time they had ever done it. I'm no machinist and I can't be sure about the quality of their work. The only concern I had was that one bolt threaded into it's hole with some difficulty, that is, it required a wrench to get it seated in the last few turns. I tapped the hole once to clean it up but that did not help much with the threading. Don't know if that's a sign of poor workmanship or not. I'm just now ready to put it back in the truck and fire it up. Just in time for the Israelis to bomb Iran and diesel will go to $10 a gallon.
Black 95 6.5TD, 929 block, 173k miles, 65k on IP, 48k miles on self-rebuilt engine done in '09, 6 L&S Full-torque inserts in outer main crank holes, Clearwater heads, Fluidamper, rebuilt NV4500, 3" downpipe, 4" exhaust, no cat, dual T-stats, 9 blade fan, spin-on 180 degree clutch, Heath hi-flow water pump and turbomaster, PMD relocated, OPS relay mod, Heath PROM upgrade, and Kennedy headlight harness upgrade soon. Now use semi-syn Lucas 2-cycle oil every fill-up which greatly reduces the frequency of DTC 35-36 codes the PCM/ECM throws.
