Results 21 to 40 of 44
Thread: Rings and bearings while I have the engine out?
  1. #21
    Jul 2024
    USA, PA
    Main 3, cap:
    Main 4, cap:
    Main 5, cap:
    I haven't looked into the number yet, but the first thing that caught my eye was the difference between the main cap bearings for 1, 2, and 4: 1 has 973S on it, but 2 and 4 have 974S on them, even though the part number for all 3 is the same, and the block side bearings for all 3 mains are exactly the same.
    1997 6.5 K2500 Suburban, stock except for relocated PMD (grill)
  2. #22
    Good deal
    RODS ARE STANDARD.
    Use plastigauge to check clearances
    NOT PERFECT....But it will get you close enough to know wassssup.....
    Too tight....BAD JU JU
    Too loose just as bad
  3. #23
    Quote Originally Posted by malpana View Post
    Main 3, cap:
    Main 4, cap:
    Main 5, cap:
    GM indicates in their service manuals that different bearing halves can appear on the same journal. This is sometimes done to split the difference in bearing clearance to help get a more perfect fit. For this last engine I/we rebuilt, I used a standard set of rod/main bearings even though the engine originally had a couple of unmatched bearing sets from the factory. I didn't worry about it during the rebuild because all clearances were checked and all were in the mid range for acceptable clearance using Plastigage. To boost confidence, I inside/outside mic'ed the bearings/journals, and found the Plastigage to be just as accurate (and much faster) as I could measure with good mics.
    Time will tell, I suppose, but the engine has about 5K on it now. Oil pressure is typical and it is amazing how smooth the engine is when idling. I plan to shoot some video of the idling engine in the weeks ahead with a clear plastic cup half filled with water sitting atop of the intake manifold.
  4. #24
    Jul 2024
    USA, PA
    Thanks, More Power. Good to know plastigage can be trusted. I'll use it.
    Any ideas about this: "the difference between the main cap bearings for 1, 2, and 4: 1 has 973S on it, but 2 and 4 have 974S on them, even though the part number for all 3 is the same, and the block side bearings for all 3 mains are exactly the same." That's got my wondering.
  5. #25
    One of the biggest influences on the idle "Smoothness" is the pop pressure on the injectors.
    AS IN having them all very very close to the same pressure....
    A set of squirts that are scattered all over the map with some low and some high can make for a rougher running engine.....
    This difference also places more torsional stresses on the crank as well....
    I had the shop that rebuilt my squirts on the last 6.5 I built tweak things down to as close as they could get to perfectly the same.
    Maybe this is being too anal....But that engine was a smooth runner.....
  6. #26
    Jul 2024
    USA, PA
    I'll see about getting the injectors checked.
    No crack in the block, so I ordered a set of Clearwater heads. I might go with Flepro for the gaskets and bolts, but does anyone have any strong opinions? What about Mahle gaskets? The block has most likely not been resurfaced. In the absence of absolute certainty, is it better to err toward standard thickness or +0.10"?
  7. #27
    FELPRO is the best gaskets and bolts....
    Check the deck height when you get a piston/rod back in.
    With the piston at TDC it should be .004" to .006" above the deck. (Out of the hole)
    I have seen the pistons flush with the deck......
    If the piston protrudes more than the .006" out of the hole then it is a good bet that the deck has been cut
    If the deck height is standard you do not need to use the thicker gasket.
    Any good rebuilder will stamp near the front of the deck or along the top upper portion a number .XXXX if the deck was cut.
    NOTE
    The bolt kits come with the torquing specs on a little sheet.
    Torque to yield bolts (TTY) Use once and then toss......Not like the old stuff we saw in SBC from decades ago...
    The torque sequence will give a number...XX ft lb through the pattern....Then a second number XX ft lb through the pattern and then 1/4 turn or 1/2 turn. ?????
    THIS IS CRITICAL....Follow the spec sheet.....TTY bolts must be put in the "Stretch zone" so they provide the proper clamping force throughout the operating temperature range....
    Make sure the bolt holes are clean and free of all oil and crud..(Brakleen.works great)
    The bolts have a dry silicone sealer on them....DO NOT oil the threads or the bolt....Install as they come from the box.....
    The threads are metric.....I like to carefully run a tap though all the holes to clear all the crap.
    Then flush with brakleen....allow to dry...
    Metric taps are available
  8. #28
    Jul 2024
    USA, PA
    Thanks, Robyn all very helpful info. I'm itching to go with main and head studs, but maybe I'm just going overboard.
    I'm also considering replacing the nylon rocker arm retainers with another setup. I know there have been discussions of this here and elsewhere, but they seemed to be mostly at the point of trying something new out. Does anyone know what's been tried, tested, and proven to work over the long haul? I'm a bit uneasy about just getting new nylon ones, and Harland-Sharps would be a hit to the wallet.
  9. #29
    I rebuilt my engine about 50K miles ago, and at the time, I was debating about whether to use head studs or not. I decided to go with the stand TTY bolts, since that was proven technology.
    However, after studying and learning more since then, I would go with head studs next time around. Mostly this is due to the fact that I am using a Holset HX35 turbo that can push 15 psi pretty easily. I'd feel more comfortable letting the boost go where it wants if I had a studded engine. As it is, I tend to be cautious and keep my foot out of it when towing to prevent high boost situations.
    I don't know of any other options for the nylon buttons (other than the Harland Sharp rockers, which aren't necessary for a stock build). I put new nylon buttons in my engine and am satisfied with those.
  10. #30
    Jul 2024
    USA, PA
    Hi, all. I hit a snag getting the pistons and rods back together. One of the wrist pin bushings was cracked. I can't find a GM part number for it and am having trouble finding an out-of-the-box replacement. Enginetech sells sets, but they need to be honed to fit, and I'd like to find them sold individually, if possible. I'm assuming I can't just get a new GM rod without having it balanced with the others. Any ideas? Thanks.
  11. #31
    Hey
    Tomorrow I will snoop in the shop
    I think I have some piston/rod assemblies for the 6.5
    If I do I am happy to send you one.
    I need to make sure they are 6.5
    These are not balanced in sets.
    The rods are balanced to a standard spec and will be fine to go right in.
    I will look in the morning and then get back to you...
    If I do have you can PM ME an address and I will get it on the stage heading your way.
    Which cylinder ????
    Later
  12. #32
    Jul 2024
    USA, PA
    Wow! That would be fantastic, thanks. #6
  13. #33
    No worries
    If the ones I am thinking of are still where I think they are....
    I will let you know...
  14. #34
    I got in the shop a bit ago.....Bad news...The parts were where I thought.....Sadly they are from a 454 and not a diesel....
    Sorry ....
  15. #35
  16. #36
    Jul 2024
    USA, PA
    Just bought one. Thanks for looking in your shop and online. Much, much appreciated!
  17. #37
    Glad you got one coming.
    Good luck on the project
  18. #38
    Jul 2024
    USA, PA
    Hi, all. I'm about to put the rocker arms back in and need to get the engine to about 30* BTDC. I've got a Fluidampr and am wondering what reference on the engine I should use. I know the markings on the balancer go from 50* BTDC to 10* ATDC, but does that mean the 30* mark should be at 2:00? That would put 0* at about where the first lower water pump bolt is - that's what the manual says to do with the mark on the stock balancer. Any help would be appreciated.
  19. #39
    Why are you wanting 30 degrees
    Put the push rods in the correct way with the marked end up to the rockers.
    Bolt the rocker shafts on and get the push rods into the rockers and then snug the rocker shaft bolts down slowly.
    Once the rockers are in snug (No valves hitting) torque the bolts....Move on...Good to go.
    Roll the engine over by hand and observe that all the rockers are moving correctly.
    Before installing the valve covers.....Prime the engine with oil.
    Use a modified old style vacuum pump .GEAR TEETH GROUND OFF TO ALLOW THE OIL PUMP DRIVE TO BE ROTATED FREELY.
    Remove the pump diaphragm assembly and weld a nut on the shaft to allow it to be turned with a speed handle or an electric Drill
    RUN THE PUMP UNTIL OIL comes out of EVERY pushrod.
    Rotate engine a bit during the procedure .
    Be sure to plug the Turbo oil feed port so oil will not make a mess....
    Place a gauge in the rear oil port (Sending unit port) so you can see the pressure.......
    YOU CAN'T PRE LUBE THE ENGINE WITHOUT THIS TOOL.......Starting a dry engine to get oil into the system is a bad idea....WAAAAAAAY too long of a run time without oil pressure on a dry engine.
    Good luck
  20. #40
    Jul 2024
    USA, PA
    Hi, Robyn. I was following the shop manual and also found these instructions online:
    The rotating instructions are the same between them, except the online bit explains that 3.5" back from TDC is 30* BTDC (no valves close to pistons). I just checked my PDF of the shop manual, and it doesn't talk about TDC and BTDC at all: it must be a different revision than my hard copy manual. Anyway, I guess it doesn't matter.
    About my pushrods: they don't have any markings or coloration at either end. I know what end was up, so that's no big deal. I'm just curious why mine don't have any "up" indication. Thanks for the priming tip!
  1. Mahle Piston Rings vs. EngineTech Piston Rings
    By Aftermath in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 06-17-2016, 07:59
  2. rings well just one
    By guyina4x4 in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 07-23-2015, 14:54
  3. Rod bearings ??
    By BorJansson in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 03-13-2013, 16:17
  4. Differential Bearings?
    By bmiszuk in forum 1982-2000 C/K Truck & SUV Chassis & Drivetrain
    Last Post: 04-03-2007, 18:06
  5. Are rings rings?
    By AltitudeDiesel in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 03-31-2006, 18:30
