Results 1 to 7 of 7
Thread: How do you all get 6.2s to 300K miles?
    Jan 2025
    Midwest
    Post How do you all get 6.2s to 300K miles?
    I hear often about 6.2 Detroits going to 300K miles and more, but can they really do that? My 1990 K5 Blazer with a swapped in 1985 6.2 Detroit Diesel w/h the ATS Turbo Kit which is at 85K miles (the vehicle itself has 279K miles) ... Already have quite a few in it with the following:
    Fluidampr swap from harmonic balancer
    4 row Aluminum Radiator
    4L60E Transmission (plus a Hayden external cooler)
    Spin on filter + water separator
    Radio + sound system
    Transmission temp guage
    That and other miscellaneous stuff such as new seals, bushings, window motors, hoses, mechanical stuff, new grill, etc.
    The engine and transmission are fine (except for the engine leaking oil part), but this is all just normal wear and tear for a 40 year old vehicle, I just use it for regular plain old driving, no towing or anything.
    I live on my installation, where damn near all my daily trips are within a 2-4 mile radius, so as of now, I change my oil every 3K miles. I use the Rotella T4 varient as (as stated prior) I leak quite a bit. Though if any other options are better, please do tell.
    But for those who own similar applications, what do you all do to keep these vehicles going?
    (Photos of said vehicle, including paperwork from previous owner:
    https://photos.app.goo.gl/ksTMNAVU6ra73RpK9 )
    My 85 blazer did that, twice and then some, on the original long block. Head gaskets replaced about mid way (for maintenance purpose, no leaks), and a diet of synthetic oil every 5K miles, whether it needed it or not. No turbo, but the pump was turned up as far as the heat would allow. Most trips were long enough to get it fully up to temp. It had no easy days, and it never knew it wasn't a 1-ton. It was semi-retired in 2001, then parked awaiting a resto in about 2010. The last 10 years put less than 10K miles on it. It's used up, for sure, but will still run today with a minor refresh (batteries, underhood rubber, etc.), although I wouldn't drive it as it is.
    Maintenance is the key for sure.
    As Maverick said.....
    Replacing head gaskets (I consider these to be a "Consumable" )
    Keeping fresh antifreeze in the cooling system is also a great way to lengthen the head gasket life....Coolant loses it's additive package over time...Plus if the Glycol is mixed with Nasty water that has a lot of minerals in it (TAP WATER IN MANY PLACES) can cause corrosion and degradation of the metal rings on the gaskets and also the block deck surface...
    Oil changes.....Diesels get a lot of carbon in the oil.....This stuff is abrasive to a degree and causes wear.....
    A good high grade diesel rated oil is paramount....Some folks just grab whats on sale at the MART STORE and Good to go.....
    Sludge and other junk wreaks havoc on these engines.
    Common to see rings stuck causing a lot of blow by...
    Clean....Very clean fuel helps keep the injectors and the IP in good order.
    Air filters....Keep them fresh.
    THESE THINGS...plus a bit of luck....The high numbers of miles are quite possible...
    Sep 2001
    Ft. Wayne, In.
    I (and my kids) drove my '82 6.2 to 345K miles. I changed the head gaskets only once at about 300k. Started and ran great. Had plenty of blowby but still was a good runner and great on MPGs.
    I only got rid of it because it really needed a new truck under it!
    I have a line on another '82 for a beater truck. Pretty cool trucks for sure....
    d
    Dave, N9LOV
    Member #242
    Dave's Diesels:
    '97 2 Dr Tahoe, Intercooled,
    Kennedy ECM, 4" Exhaust
    '02 GMC
    Quote Originally Posted by DieselDavy View Post
    d
    How many miles have you got on your 2 door now?
    Dec 2012
    DeFuniak Springs, Florida
    I have been a member here off and on since Jim started it. Ive owned 6.2's and 6.5's continuously since 1984. It began with me buying 1.5 ton dually's with 6.2 and turbo 400 transmissions. Construction material delivery trucks in Florida. I averaged about 175k befrore head gaskets. HOWEVER, in my personal vehicles: Ive driven Suburbans since 1984. All have been 4wd K2500 HD Suburbans. I ran synthetic (Mobil then Amsoil). Two 6.2 J code diesels ran past 300k. A 1991 went to 320,000 miles with virtually no blowby. I sold it with that mileage. Rest of the truck was extremely nice. Same was true of a 87 J code. It went to 307k miles and a head was leaking....I put head gaskets in it, drove it awhile and sold it.
    So I have owned two 6.5 Suburbans that went over 300,000 miles. I think the key is to 1. MAKE THE RECOMENDED CHANGES TO THE ENGINE. (Look on Youtube for :How to bomb proof a 6.2/6.5 diesel. 2. Change the oil and filter every 3000 miles. I prefer OBS Suburbans with 6.5's to all the other "new ones". Good, dependable, comfortable SUV.
    Dec 2005
    Klamath falls/keno Oregon
    430,000+ on my 6.6 all original except for the turbo...I use Amzoil every 10k miles
    Hummer wheels :^)
    dual lift pump
    Banks air intake
    429,000 miles and counting..
  1. How many miles
    By Carbon D/A in forum Duramax 6600
    Last Post: 11-17-2005, 16:42
  2. most miles on a 6.2
    By HANK1948 in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 05-20-2004, 04:55
  3. most miles on 6.5
    By Keith Richards in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 05-04-2004, 20:00
  4. Brokers 300K dmax update
    By pullinpower in forum Duramax 6600
    Last Post: 04-09-2002, 13:25
