Thread: Sources for Electrical Connectors & Harnesses
    Thumbs up Sources for Electrical Connectors & Harnesses
    I shot the above image from a video I watched recently about automotive electrical connectors. The author of the video indicated that this company can match you with a new connector using just a photo of the old one - or you can order one by providing other information.
    I also saw another video that offers wiring harnesses for the 6.5 - like this one that can be found at the rear of the engine valley in a 1994 or newer electronic 6.5. That 15-pin plug can be affected by corrosion in those trucks driven north of the Mason/Dixon line during the winter. Not cheap though... This harness is currently priced at $214.
    See: https://quadstartuning.com/collectio...nt=41414604242
    I purchased that harness from Quadstar 3 years ago when I rebuilt the 6.5L in my Tahoe. I didn't want 30 year old wiring to be the cause of future problems.
    I have purchased quite a lot from Quadstar over the years. I believe they are now the premiere source of quality 6.2L/6.5L parts, and they are 6.5L enthusiasts themselves.
    In fact, I just purchased a chip for a friend's 1994 C3500 that had the now obsolete 5068 pump, and the replacement 5521 pump required the updated "current" programming.
    Kennedy Diesel used to be my go-to for all things 6.5L, but he's pretty much stepped out of the 6.5L game and is focusing on the Duramax line.
    You're right!
    Sourcing parts is becoming a bit more difficult. Staying up with the good vendors who are providing support is important. I hope to help that this summer by working through an engine build of another 6.5 (the spare one I bought a few years ago). This'll be a complete rebuild if the engine is ok inside. We'll see...
  1. I Need to plug the wiring harnesses back in 96 Suburban I pulled the wiring harness
    By jrsavoie in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 02-09-2015, 15:11
  2. Where do these connectors go?!
    By George301 in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 08-31-2014, 14:17
  3. Gauges & electrical
    By bmiszuk in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 09-26-2013, 15:28
  4. Frame Replacement Opinions & Sources?
    By crashz in forum 1982-2000 C/K Truck & SUV Chassis & Drivetrain
    Last Post: 05-26-2010, 11:53
  5. 94 vs 95 connectors..
    By 1bad383 in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 06-24-2004, 14:01
