Thread: A fuel leak has sprung in the valley underneath the intake manifold on my 85 6.2...
    Jan 2025
    Midwest
    Default A fuel leak has sprung in the valley underneath the intake manifold on my 85 6.2...
    As the title states, a fuel leak has sprung down there, we already tore off the intake, turbo housing, however we couldn't find exactly where its coming from, I have a video of said leak, but its really hard to pinpoint, I hope its just a line, and not the IP itself.
    Any second opinions would really help, i did replace the rubber lines when I was in there, did not touch the metal lines though
    Attached are the videos of how it looked like/how it ran without the manifold, photos will be attached on this post aswell
    https://photos.app.goo.gl/N3HHPGKi3TeCws6w9
    Thank you again.
    (Also, I have some oil coming from the intake, bit uneasy about it)
    - 1985 6.2 Detroit Diesel Motor w/h ATS Turbo Kit
    Throttle shaft leaks are common on these....
    If you can get get a good look at the area right below the shaft you may find the gremlin.
    Yes, the throttle shaft is a common suspect. If the IP or any line connections are leaking, they will be wet with fuel long before you'll notice any collection in the valley. Return lines are also suspect.
    Some oil in the intake is normal. The CDR (Crankcase Depression Regulator, the tuna can next to the oil fill pipe on your 85) allows some oil vapor into the intake. This does not mean it's bad. Some oils vaporize more than others, and more blowby (older, high mileage engine) is more crankcase pressure that passes into the intake, ahead of the turbo compressor, which may also have a coating of oil. The CDR's ONLY purpose is to prevent excessive crankcase vacuum (depression) at higher RPM's and other conditions, such as a fouled air filter or air inlet. Combine this with the EGR (if it's still working), will result in a gooey mess in the intake tract, but it's essentially benign, even after many years and miles.
  1. C-code intake manifold to HMMWV intake manifold swap questions
    By AJMBLAZER in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 03-17-2016, 07:10
  2. fuel leak under intake manifold - 83 chevy van
    By DungBeetle in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 07-08-2009, 12:44
  3. How to test intake manifold for leak
    By RunMonkeyRun in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 01-25-2007, 14:03
  4. Intake manifold gasket leak
    By Blzr6.2'83 in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 07-04-2005, 06:09
  5. Oil in Engine Valley - Intake manifold R&R
    By slagona in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 10-24-2003, 09:58
