Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
Thread: My cost to replace my 6.6
  1. #21
    Dec 2005
    Klamath falls/keno Oregon
    well, I guess I didn't update this thread, the water leak was from the heater hose..I replaced the leaky one.. F7nsnp12 mines an early truck too.
    Hummer wheels :^)
    dual lift pump
    Banks air intake
    429,000 miles and counting..
  2. #22
    Thanks for keeping us in the loop on your journey. BTW - I visited Klamath Falls in 2007... its not that far...
    If I were a younger guy I'd go into business replacing Duramax head gaskets, injectors, pumps, and complete engines. The fear from the "look of complication/difficulty" goes away after having done a couple of them. The costs charged by dealers/shops today are so utterly outrageous. My two Duramax engines continue to run/perform very well - coming up on 4 years since replacing the head gaskets, injectors and other stuff in 2021 - but then I've been doing this sort of thing (GM engine work/replacement) off and on since I was 14.
    Dec 2005
    Im starting to worry about my injectors now, 428,000 miles on them.. My best friend lives in eureka I came here from Bishop, Calif in 2017
    Hummer wheels :^)
    dual lift pump
    Banks air intake
  4. #24
    Post Cost of things...
    Quote Originally Posted by spongebob View Post
    My engine has 425,000 miles, why spend 8-10k for head gaskets then the fuel pump dies, the oil pump dies, oil pressure drops…
    Just my humble opinion... These trucks eventually reach a point in their life cycle where they become own-able only by those who are their own mechanic. Your truck sounds like one that a owner-mechanic would love.
    In 2021 I replaced the head gaskets in my 2001 GMC crew cab for $3500 or so. This gave me a new set of injectors, head gaskets, water pump and ancillary consumables, plus the special tools to do a good job. Lil Red, on the other hand cost only ~$300 to replace the head gaskets and a few consumables. Lil Red runs perfectly today.
    My GMC, as of June 2025 may need another set of injectors (and maybe more... won't know for sure till I get into it). The GMC has just 20K miles on it since the work/expense of 2021. Have to say I'm disappointed...
    The above is a brochure from the shop here in Montana (near Bozeman) that did the head decking for my GMC head gasket project in 2021. It's basically a well equipped 2 man shop that specializes in Cummins, Powerstroke and Duramax engine machine work. Another shop, that I used for Sarah's 6.5L diesel is also very good - a one man shop that did a marvelous job on the 6.5 machining work. Personally, I'd trust him to do any engine machining I needed, including for a Duramax. But, I'd do the engine re-assembly...
  5. #25
    Sep 2001
    Ft. Wayne, In.
    Jim,
    Keep us updated on your GM journey.
    d
    Dave, N9LOV
    Member #242
    Dave's Diesels:
    '97 2 Dr Tahoe, Intercooled,
    Kennedy ECM, 4" Exhaust
    '02 GMC
  1. cost to rebuild
    By rickm in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 03-12-2008, 22:39
  2. Overhaul Cost?
    By Chris Strandt in forum Duramax 6600
    Last Post: 03-30-2005, 09:58
  3. GM cost cutting?
    By Kennedy in forum Duramax 6600
    Last Post: 04-02-2004, 10:23
  4. Transynd Cost
    By Dmaxducker in forum 2500HD/3500 HD Trucks & Drivetrain
    Last Post: 01-31-2003, 19:34
  5. GM Cost Cutting on '03's
    By andy911 in forum 2500HD/3500 HD Trucks & Drivetrain
    Last Post: 08-29-2002, 22:09
