Rebuilding a 6.2l. The bores had some pitting which was probably caused by water in the oil. Engine has been sitting for a long time.
I honed all the cylinder bores and the look good.
I then measured the bores and found that They exceed the maximum bore size tolerance.
The pistons are standard and within tolerance.
Measurements of the oversize are below.
No 1 0.945 Thou
No 2 2.52 Thou
No 3 0.945 Thou
No 4 3.701 Thou
No 5 3.307 Thou
No 6 3.701 Thou
No 7 5.26 Thou
No 8 0.157 Thou
My question is is it ok to run the engine with the above parameters?
My thoughts are that the only real worry is the 5.26 thou No7 cylinder bore
Thanks
