Results 1 to 5 of 5
Thread: coolant leak
    Dec 2005
    Klamath falls/keno Oregon
    Default coolant leak
    it's on the drivers side, I thought I fixed it when I found the J shaped heater hose was leaking at the fire wall..but
    it has come back. I read somewhere theres maybe a oil cooler line that has a rubber hose in that area??
    Ive used a camera to try and see the origin of the leak..to no avail..
    thoughts..
    Hummer wheels :^)
    dual lift pump
    Banks air intake
    429,000 miles and counting..
    Dec 2005
    well well well...I made a trip out of town and on my way back home (80 miles one way) I got the coolant lever low light..I pulled over and popped the hood, steam was coming out around the transmission dipstick... seemed the heater hose went...so I added a gallon of water and nursed it home..both the trans temp and engine temp were in the "OK " range just to the right of 210*..I'll be pulling the hose out soon, the longer of the two is $112.00. So I guess that was the source of my driver's side coolant leak...I hope.
    Hummer wheels :^)
    dual lift pump
    Banks air intake
    It's usually just the plastic quick connectors. If so, you don't need to replace the entire hose assembly. The connectors are available at almost any parts store. They clamp onto the existing hose. My son's 2007 Classic needed the same a few months ago.
    Dec 2005
    thanks I;; try that 1st..I did replace the "J" hose a couple of years ago..
    Hummer wheels :^)
    dual lift pump
    Banks air intake
    Dec 2005
    I replaced both hoses and used the stainless connectors (800-409hp). Hopefully, this is my leak fix..
    Hummer wheels :^)
    dual lift pump
    Banks air intake
  1. Coolant leak
    By CoyleJR in forum Duramax 6600
    Last Post: 08-24-2016, 20:03
  2. Coolant leak
    By Kdwallis in forum General Diesel
    Last Post: 01-29-2013, 13:20
  3. Coolant Leak Help!
    By mstockton in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 02-01-2009, 11:59
  4. Coolant Leak?
    By ak46champ in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 01-18-2008, 22:30
  5. coolant leak
    By 03DMAX in forum Duramax 6600
    Last Post: 10-22-2004, 14:18
