Results 1 to 6 of 6
Thread: Heater hose "quick" disconnect....how to
    Dec 2005
    Klamath falls/keno Oregon
    Default Heater hose "quick" disconnect....how to
    when putting on a new connector, is the "tool" used that took the connector off?
    Hummer wheels :^)
    dual lift pump
    Banks air intake
    429,000 miles and counting..
    No. The new connector should just "snap" on. The tool simply moves the pawls away from the swell for removal, like a shop air hose connector. Align the fitting squarely and push it on. If it seems to resist, twisting helps. It shouldn't take too much force, unless something isn't aligned or the seal has dislodged. You should feel it engage the lock. Tug back on it to check.
    The quick connectors are used only to speed up factory assembly. I apply a swipe of dielectric grease to the fitting. It keeps the seal from gaining friction, which can damage or roll it. Repair procedures suggest lubing with coolant, which is probably OK. The Dielectric grease will (probably) still be effective if/when it has to come apart later.
    Dec 2005
    seems the "J" hose to the EGR came off...Its a new hose I replaced a year ago..any way I had both off the firewall when I pushed them back on there was no "click".. I'm running 100% water to see if it will continue to leak..it had for some time..a 1/4 cup of fluid at most.. $20 a gallon is steep for anti freeze.. when I replaced that "J" hose I replaced the thermostats...and the temp gauge has a wide swing now.. I used NAPA parts
    Hummer wheels :^)
    dual lift pump
    Banks air intake
    In my experience, the fittings rarely "click". They usually "snap" into lock, more like a detent falling into place, a slight feel, but rarely an audible click. I've never really liked the plastic connectors, but they aren't that bad, and last years. They can be eliminated, if you want. Traditional hose clamp connections have failings of their own.
    Good idea running all water until you get it sorted out. As long as the weather allows it, you aren't wasting expensive coolant. I've done that a few times over the years. You don't want to do that for too long, as the system needs the coolant for lubrication and corrosion resistance.
    Dec 2005
    it's driving me nuts, the leak at the firewall seems to be intermittent.
    Hummer wheels :^)
    dual lift pump
    Banks air intake
    Where on or from the firewall are you seeing coolant? If it's just dripping from a location, it doesn't mean that's where the leak is. Your other post started at the driver side, then the heater connector, not on the drier side. I don't know what might be on the driver side firewall that could leak coolant, unless it's being sprayed/squirted, or running there from somewhere else. If you're just finding it on the ground, it could be almost anything. The most common coolant leak (on essentially every GM light Diesel, since forever), is the frost plug block heater. Incidentally, it's on the driver side.
  1. uhhgg defeated by the heater quick disconnect ? too
    By Hubert in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 02-08-2009, 18:31
  2. Intercooler and Goodyear "Hi-Miler" hose?
    By DennisG01 in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 08-11-2008, 06:25
  3. Here's a quick fix for a "cloudy" headlight lens
    Last Post: 02-16-2005, 06:57
  4. "quick heat plugs" from Kennedy?
    By libtec in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 11-22-2004, 13:20
  5. Quick Disconnect on Heater Inlet Hose
    By MEdlin in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 07-11-2004, 09:47
