Results 1 to 9 of 9
Thread: Check Valve?
    Apr 2006
    Cedar Grove, NC
    Default Check Valve?
    Is there a serviceable check valve at the injection pump? Is there a check valve in the lift pump? My '95 is losing prime overnight if I park facing uphill. Does not seem to be much of a problem if I am facing downhill. Just replaced the fuel filter manager and this helped my problem considerable. Before I replaced that I would lose prime even facing downhill. It is making me crazy.
    84 C10 J code intake. Sold in 2020
    83 C10 Scottsdale w/veggie conversion. Lost in divorce 2015 but totally worth it.
    98 K3500 Silverado CC DRW, marine injectors, 4" exhaust (kitty cat MIA), boost and egt gauges, FSD relocated, #9 resistor thingy, reman Navistar block from Kennedy installed Jan 08, Reese Signature Series Gooseneck hitch. Lost in divorce 2015 but totally worth it.
    95 C2500 F code. Rebuilt GEP. Boost, EGT, and fuel pressure gauges. Redundant PMD with one behind bumper and one on firewall. Daily driver since Jan 2014.
    Yes, it has check valves there, and the return line. If you're losing prime, you have leaks, and/or the fuel filler cap is failed. If it doesn't vent properly, fuel contraction will pull air into what may otherwise not be a leak, like QD's and weak seals and connections. This can also cause it to pull air back through the injectors. The only positive pressure in the system should be between the lift pump and injectors, and the only suction should be between the tank and lift pump. The remainder of the system should be neutral pressure, with only gravity playing on it. Leaks lets gravity move fuel where it shouldn't.
    Apr 2006
    Cedar Grove, NC
    Thank you. I suspect the line from the FFM to the injection pump. Going to take the intake off and inspect. I am going to put about 5 psi on the system at the tank fill and look for leaks from there. Any other tips or tricks to find the culprit? When I loosen the fuel tank I do hear a whoosh but it is not clear to me if it is pressure or vacuum. Is this a clue?
    Dec 2003
    Yukon Canada
    You probably don't need 5 psi.
    First try leaving your fuel cap loose overnight in the position where you loose prime.
    If that fix's it, Awesome problem solved.
    Start with the easy stuffs, a whoosh from the cap is a definite sign to look there
    The Diesel fuel filler cap vents in both directions, and should not retain noticeable pressure or vacuum. If it does, it's failed, or it's a gasser cap. A bad/wrong cap won't cause leaks, but can exploit weaknesses in the system that may not leak, otherwise. Low air pressure on the system is good for finding leaks, but leaks that occur during vacuum (air intrusion) won't always leak under pressure. Any leak between the lift pump and injection pump should be evident under normal operation, being pressurized, the same as it would if you apply 5 PSI air to the tank. The lift pump should provide 4-10 PSI at engine idle. Applying low air pressure to the tank may show a new leak that is outside that part of the system, such as a return line, which should not normally leak at low/no pressure (during operation), but may if higher pressure is applied. Age, deterioration, and wear can also add to the possibilities.
    Apr 2006
    Cedar Grove, NC
    Did not see any leaking hoses with 5 psi on the system. Found an injector line that was not as snug as it should be at firewall on drivers side so snugged that up. Also drilled a small hole in gas cap to prevent pressure/vac issues. Parked uphill yesterday and it started this morning so making progress. Going to let it sit for 3 days facing uphill. If it passes that test I will call it solved.
    Apr 2006
    Cedar Grove, NC
    Still acting up and making me crazy. Left it parked up hill for 2 days and would not start today with out priming. I took the lift pump off and checked it out. Check valve there seemed to be working. Got everything back together and primed it and got it started. Once I got it fired up it sounded like two skeletons having rough sex and had a service engine soon light on. Shut it off and tried to immediately restart but no love. After a very long crank time it did fire back up but still loud and still SES light on. Drove it around the block to see if it would clear up. No love. Plugged in to get some data while SES light was on and it was loud:
    Had 3 error codes: Crank position error, Injection pulse width error, and Accelerator pedal position.
    Desired RPM was 600 and measured was 750.
    Desired timing was 0 degrees and measured was 0 degrees. TDC offset was -1.76. Actual pump timing was 47 degrees.
    Turned it off and immediately fired it back up, no problem. SES light is off and it is running normally, not noisy. Desired timing was 8.7 degrees, measured was 8.8 degrees, Actual was 31 degrees. TDC offset was 1.76. Desired idle was 600 and measured was 600.
    Any clues to be found in this data?
    Dec 2003
    Yukon Canada
    My 98 3500 6.5 5 speed,tow truck always had electrical issues till i replaced the ignition switch.
    Not saying that is the issue, but sometimes the issue is not where you would look.
    My 2004 Topkick had a bunch of electrical issues to. The main issue was the heater didn't work.Changed the heater control with no luck.Had a lead hooked to the blower fan that i would clip to a power source for heat. When i did that other things would work while getting back feed through the harness. A new ignition switch cured it's electrical issues
    The trans in my '95 would go into limp mode. Dealer rebuilt the trans on warranty. Finally, a new ignition switch cured it...
  1. PPE Boost Valve vs. Kennedy Boost Valve
    By paoutdoorsman in forum Duramax Diesel Performance Shop
    Last Post: 12-23-2006, 09:37
  2. 4L80E Boost Valve / Valve Body DIY'ers?
    By damork in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 05-18-2004, 13:14
  3. oil cooler check valve
    By jtostenr in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 03-31-2004, 09:41
  4. Lift Pump Check Valve
    By britannic in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 11-03-2003, 19:41
  5. Broken Valve or Valve Spring?
    By flyboy2005 in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 08-28-2003, 19:24
