No the engine was only cranking slowly when the injectors were still in and all the fuel lines on. The starter was drawing over 600 amps at that point. But with teh injectors pulled and the fuel lines removed, the engine spins quickly and easily.
still seems a little odd to me the slow cranking issue... Here's my current question; How would no compression in three cylinders slow the cranking speed down? seems odd.
