I think the banks instructions should include a paragraph suggesting an upgrade to an electric pump. I made the mistake of not following the instructions exactly in order when I installed my banks kit and ended up installing the lift pump after the exhaust manifold. That was bad enough.
Now that my engine's out of the truck, it's getting a nice low maintenance block-off plate instead of a mechanical lift pump.
1983 K5 Blazer, bored 6.2, 4911, 6.5TD heads and injectors, Gear drive, Banks system, Dual t-stats w/ high flow water pump, D60, 14BFF, Rear Disks, 4.10s, 37\" Swampers, Warn M8274-50, Bad paint and almost no interior
