I have discovered an intermittent howling noise at free way speeds. Sounds like it is coming from under the hood. Kind of like blowing into a bottle and making it howl.
2002 3500 D/Max/Allison, Forest Green, Tan interior<br />4x4 LT. Dee Zee Boards, Catch All Matts, EGR Bug Sheild, Mud Flaps, Tonneau Cover, Bed Matt, Palomino 10ft. Slide-in Camper, Tork-Lift tie downs, Rancho 9000 Shocks.
Engine cooling fan cutting in most likely
Road Kill,
I've got it too. But it does'nt start until around
70 mph. Or, if accelerating hard getting on the
freeway. Seems to be more pronounced in cool moist
conditions. Called a service tech months ago about
it. His response, "If you stay under the speed
limit, you will not have a problem"... Unfreaking
believable. The real funny part is he was serious.
My guess is that it's the turbo. My father-in-law
has a FPSD and it does it too. Have not pursued
any further...
Jimamatic,
Tell your service tech you were traveling through OK where the LEGAL speed limit on interstates is 75 MPH...
Road Kill,
I'd tend to agree with MaD MaX - probably the cooling fan kicking in, it is quite noticable when it turns on.
I've found this truck makes all kinds of different noises at different times. I think if you start paying attention to them it'd drive you crazy.When you hear a noise one day it is gone the next.Just keep driving that sucker and keep an eye on the guages, check the oil regularly,and look underneath for possible leaks. I imagine for most of them after 200,000 miles you'll still be doing that routine and nothing will have happened. Stu
2002 GMC 2500HD D/A. CC. LB. INDIGO BLUE <br />Custom Lining bedliner,Quick & Easy hitch receiver,Snugtop cap,Trailback running boards,135 Gal. Auxtank,Moryde RL suspension,Alison deep sump, Jordan Ultima 2020 brake controller.<br />26\'Sunnybrook 26CKS TT,<br /> Blue Ox equalizing hitch,2 Honda EU2000i generators in parallel. <br />25\'Bayliner Flying Bridge cruiser.
It's your air conditioner doing it. Mine does it too, like you said, only above 70 mph.
I verified this by turning the air on and off above 70 mph...definitely made the noise come and go.
I talked to the service manager about it and he told me the only way to solve it is to lengthen the coolant/pressure hose and insulate it with really thick insulation wrap. They did this with an angry customers vehicle and it made it much quieter.
Vincent
2001 Chevy 2500HD 4x4 DuraMax/Allison (Pewter)
Thanks very much for all the input guys. The air conditioner is possible as I just started to use it lately. I was running about 75 with the air on when we heard it. Could be cooling fan also but it is the 1st time I noticed it and should have heard it before. I will check out the air conditioner theory and report back. Just for the record my dealership service is very poor. I hope I don't get anything bad wrong. Thanks again.
I think Vincent has hit the nail on the head. Mine does it too. I turned the A/C on and off during a trip to Ky. and it is definitely related to A/C. I was going to ask about it here on the forum but it's kind of hard to explain these little noises sometimes. I would have never guessed the hose/insulation as a resolution. I just thought it was a noisy compressor.
2014 K2500HD Crew Cab LTZ Duramax / Allison 4x4
Insulate what hose? Where? With what? Just want to know for future reference.
Thanks, John
VOLUNTEER FIRECHIEF "Without COURAGE, all other virtues lose their meaning" Truck Info
indigodually@hotmail.com
Member # 7674
Pulling many trailers including an '03 34' Montana 5'er adapted to G/N
Saw It ... Wanted It ... Had A Fit ... Got It...Then Sent It Back!
Well guys in my case it is not the air conditioner. It made the noise both with air on and air off. I am leaning to cooling fan or turbo. Truck runs great and I am hard of hearing so the heck with it. Drive on! lol Thanks for all your input guys.
Hmmm, if I had read the thread when first posted...
We were just through Midland, and actually spent Saturday night in Auburn...
Nope, I don't think it's the cooling fan or the turbo. Those are both very distinctive. Cooling fan sounds like a B-17 taking off. Turbo is a whistle that increases to the point that only dogs can hear.
I have the same problem and it is NOT AC related. Happens over 70mph or a little lower if there is a headwind. This "blowing in a bottle" sound is something airflow related at the base of the windshield. I haven't been able to find out exactly where yet.
It does drive me crazy though. Nice quiet ride interrupted by intermittent howling that I can hear over the radio.
Gary<br /><br />2002 Chevy 3500HD, Duramax, ZF-6, Crew Cab, LongBed<br /><a href=\"http://www.teamSMR.com\" target=\"_blank\">www.teamSMR.com</a>
Dang, I would have been very happy to meet you John and better yet I have a spair bed room. lol Real Big Truck we are hearing the same thing and I am stumped. Wife says it is out side wind noise . She is not often wrong! lol Just to share info. I had the wind shield noise and used some Dow Corning RTV Aquarium sealer to go down both sides, (vertical) with a small bead of RTV. End or noise! Big thanks to this forum, great as always! Now about Casper?
Just throwing an idea here.... You say it did it with the A/C on AND off. How do you know it was really "OFF"? From what I hear, the A/C compressor is activated in all but one dial position! Maybe just for a test, try unhooking the clutch wire connection.?
In some of the older C/K trucks they had a TSB about A/C compressor groaning and it involved a replacement compressor mount that would somehow not transfer the "normal" howl/groaning through the engine/driveline.
Thomas J. McCauley Jr.<br />Tommy\'s Lawn Service<br />Member # 5589<br />1990 K3500 SRW Ext.Cab Long Bed 454/400 3.73<br />1975 K20 Suburban 350/350 4.10\'s <br />Tows 16\' Landscape Trailer<br />BOSS 8\'2\" V-Plow<br />7-11 MPG !!!<br />Duramax here I come!!
Lawnboy is correct. The a/c compressor will turn with even the vent/fan in the blowing position.
I've personally verified this...considering that I live in New Mexico (read: hotter than all get out) I run my A/C quite often.
It will indeed make the humming noise above 70 mph. listen to it as it cycles on and off, then you'll become believers.
Vincent
Learning every time I get on the forum. I will try to make sure the air is completly shut down for next test. We had the air on at 75mph on the freeway, and it was howling. Just hit air off and it still made noise. I did not think to change the control setting. Thanks guys, I will report back.
OK. Here's a new one for you...I just heard the noise, along with everyone else in my truck at the time...a howling sound with the a/c on but not at high speed. I was coming to a stop sign when I first heard it! Like a mad person obsessed with any new noise, I have been driving around with the windows open and no radio, with the a/c on and the a/c off listening for that sound. It happens with the a/c on only but at low speeds.
2001 Chevy 2500HD ext cab, LB 6spd light pewter.
My a/c has done this since new. starts to "whine" at about 68 mph. Shop foreman looked at it last year and said nothing sould be done. The mounts for the compressor are pretty beefy. I had it in this week and they replaced the belt tensioner. Noise is still ther, but not as severe. If you have this noise get your shop to notify GM. If enough people complain there will be a fix.
Topic moved to 2500HD/3500 HD Trucks & Drivetrain Forum.
