I'm cleaning my Amsoil air filter today and the MAF looks dirty and a bit oily. I don't notice any performance issues and I don't want to mess it up so--- What is the best way to clean the MAF?
Thanks in advance,
Bob
Thanks in advance,
Bob
2001 GMC 2500HD D/A, CC/SB,<br />Olympic White, *Manik SS brush guard and nerfs, *Hella driving lamps, Velvet rides, *HD Air Lifts and Compressor, *Snugtop bed cover, *Linex, *Yakima rails on cover (mt.bikes), *Amsoil 2 stage airfilter. *Pioneer XM Radio. *SUBSTANTIALLY upgraded speakers,<br />Amp and Sub. *One piece drive shaft. *Mag-Hytec diff.cover, <br />*43 gal across the bed aux.tank (American Tank), *Lucerix pwr / heated mirrors, *Allison deep pan and transyd, *Street Pilot III GPS. *Suburban-type lighted <br />double sun visors, homelink system,steering wheel stereo controls, *Kennedy
Bob, JK has mentioned in the past he has had good luck using Electra-clean made by CRC, it doesnt leave a film of oil like standard brake clean might. I suppose you could use rubbing alcohal also.
2003 GMC Sierra 2500 HD CC Shorty
Dyno Proven - 800 rwhp on fuel only.
Trans to hold it and a big ol S400 turbo feeding it.
I think it was JK that mentioned alcohol. I have never looked at one but it sounded as though you don't want to touch it. I believe he just held it by the little mounting plate where the wires plug into and dipped it into a jar of alcohol and GENTLY swoshed it around a little.
Steve
Do not use rubbing alcohol to clean the MAF Sensor. When you have questions first try using The Diesel Page search features. Here is a distillation of past cleaning procedures for the MAF Sensor.
Gently rinse the MAF sensor back and forth inside a plastic bag filled with high proof alcohol. Use either 99% isopropyl alcohol or 180 Proof Everclear and not rubbing alcohol. Rubbing alcohol is 70% alcohol and 30% oil by volume. This added oil will damage the MAF. Sensor. Ask a local pharmacist or distiller if necessary.
[ 04-27-2003: Message edited by: et ]</p>
2002 2500HD ExtCab LB 4X4 LT D/A
et thanks for clearing that up
What? Use Everclear for washing truck parts!?!?!?
Its bad enough that Virginia pulled grain alchohol off the shelves at the ABC store several years ago, now you guys are using it to wash engine parts!![]()
\'02 Pewter 3500 LT CC LB 4x4 D/A G80<br /><br />Predator v1.11, Warn M15000, BFG 235-85-16 ATs, Crimestopper Remote Start, 2.5\" Front Leveling Cams, Prodigy Brake Controller, Nasta Nerf Bars, UNI Foam Air Filter, Fumoto Valve
Thanks et, very important detail!
Steve
et,
I think that 30% is water. Either way don't use it as you described. I would use the electra-clean as it's made for it. Used to use freon, of course not anymore.
2001 C3500 Charcoal Grey, Lotsa Putco stainless stuff, CB with 250 watt amp, TST Competition box, 600 watt inverter
Not to get technical but rubbing alcohol does not use water as a dilutant.
If most people knew what was in rubbing alcohol, they would never use it. By law, the last 30 percent of Rubbing Alcohol contains 250 mL of diethyl phthalate, 40 g of CAMPHOR OIL and either 700mg of Bitrex or 175 g of sucrose octaacetate.
Diethyl phthalate, sucrose octaacetate, and Bitrex are all bitter tasting chemical compounds. Bitrex is supposed to be the most bitter substance yet discovered.
These three bitter chemical compounds are also poisons. For instance Bitrex contains the following chemicals: Acetone, Benzene, Butanol, Chloroform, Ethanol, Ether, Ethyl, Acetate, Isopropanol, Methanol, Methyl Ethyl Ketone, Petroleum Distillates, Toluene, Water, and Xylene. The percent of water in Bitrex is extremely small.
At least in emergencies or simulated emergencies you can drink Everclear as long as you cut it with some other drinkable liquid!
[ 04-28-2003: Message edited by: et ]</p>
Good posts all, especially et. a64 did you spend any time in the gulf this time?
Bob
et, we can talk about balancing rates and fuel filter microns and shift ratios and synthetics lubes and .......blah blah blah.... You have officially confused me, I have no idea what you said but I could tell it was scientific cause I couldnt read those big words.![]()
OK, nobody ask ET to explain anything else, it makes my head spin!!
et, thanks
Did the alcohol (not rubbing) and plastic bag thing. Looked much cleaner when done. Truck seems to run a bit better and no codes set. I did have to buy a "no tamper or security torx fitting to get the screws off. T20 is the right size. Stuck it in the glove box for the next time.
Regards,
Bob
Bob,
Not there for either war. Was there in 98 when the arms inspectors were kicked out, but Clinton lacked the balls to send us in then. Was there this time last year when we were going to go "deep" and do some things and didn't, and apparently Bush descided not to play games and just get rid of the problem. Anyway I retired just prior to anything getting serious.
