I and probably MANY others would love to SEE the report, what "Other Diesel Website" is it? I don't think the Admins here try to hide the names of other websites from us, and wild-goose-chasing ain't my thing [img]smile.gif[/img] This way, we can see the report copy??
Questions from a skeptic who's seen alot of "tests" come and go, getting disproven or discredited as advertising/anti-advertising hype on the sly:
At what airflow rate were the filters tested?
To standardize it and give the pressure drop (in inches of water) they must have a specific airflow rate in CFM or lbs. per hour of air.
This is important in determining if the 40% worse airflow of the worst filter (vs best) is or is not significant.
Saying that 40% worse airflow won't affect performance goes against engine performance building experience of race teams and companies the world over.
If you deny this then here's a challenge for YOU:
IF you, and everybody reading this, believe there is absolutely NO performance loss, based on "0.06 psi loss" pre-turbo...
ALL of you go out and PUT AN AIRFILTER ON _YOUR_ truck that is only 1/10 the size of the current one, maybe a valvecover breather filter. Then you will "ONLY" be losing 0.6 psi pre-turbo...right? Or, put layer after layer of filter material around it so you get 99.99999999999% filtration efficiency, because it obviously hurts nothing.
Why NOT put in a breathercap-size airfilter, if you believe? Too hard? Imagine all the money saved buying really small filters! Dumb ol' GM, putting on a filter that apparently could be 40% smaller...well, based on 0.06 psi, it could be 16 times smaller and only cost a measly 1 psi pre-turbo restriction. GM, Ford, Chrysler, everybody who has bought WHATEVER brand bigger airfilter and gone faster, all those race teams the world over...sure are dumb. Include me, my truck went from (an average of 3 passes each) quartermile 16.71@79.0mph to 16.60@79.8 mph; 0-60 went from 9.14 down to 8.94 seconds, JUST by putting on a [Brand X] performance airfilter. Amazing? No, but about a 10+ hp increase...
10hp here, 10hp there, pretty soon it adds up! [img]smile.gif[/img]
Again, what is the airflow rate tested at in CFM?
If it's around 453 cfm (the amount of air needed to make 300 crank hp) it is to be considered; but many of us may have Juice boxes etc and be making over 500 crank hp (755cfm)...
Is there a website or page we can see the PHOTOCOPIED test report from the company? If it costs $1700 each filter, and the machine cost $285,000 there MUST be at least ONE scannable sheet of "Test Report" we can all see.
Probably the SCANNED PICTURE of the test report will give the CFM airflow rate and the picky "Devil is in the Details" stuff it takes to convice us Skeptics [img]smile.gif[/img]
Hate to see all that expensive testing and machinery go to waste without so much as one sheet of paper produced to LOOK at.
Thanks for the info, once we see the real report and can judge ourselves! [img]smile.gif[/img]
"TRUST, BUT VERIFY"--Ronald Reagan
