Results 1 to 2 of 2
Thread: 6.2 starting.
    Feb 2020
    New Zealand
    Default 6.2 starting.
    Hi guys. I have owned many 6.2 and this is the first time I’m stuck. The other morning my truck stopped a couple times on way to work I pumped diesel filter and got to work fine. I used the truck during the day and on way home it died but got going twice more then had to get tow truck. I have replaced filter and glow plugs and I checked cut off on top of injector pump was working good. I seem to get good pressure as have electric pump and mechanical one also. I thought this would solve the problem as always before but after charging the batteries I went to start and no joy. I tried a couple times then I cranked it for a few minuets straight then fired and ran sweet only for a minute. I then used a fuel can with hose to filter( with hand pump on top ) I pumped up and did the same again. It’s my every day driver and I don’t want to drive my jappa truck tomorrow any help be great guys.
    How old is the fuel filter ????
  1. Need advice on starting 88 P30 6.2 Diesel that has sat 8 years
    By Chevy P30 1988 in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 12-01-2019, 11:49
  2. CUCV 6.2 starting issue & Freeze Plug leak above starter
    By Trgshamrock in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 08-27-2015, 16:48
  3. 83 Chevy 6.2 trouble starting as day goes on
    By Maxamis2003 in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 06-20-2015, 13:10
  4. Procedures for starting a 6.2 crate motor
    By Gunfreak25 in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 09-03-2011, 20:13
  5. A feeling of Deja Vu - 6.2 starting problem...
    By mvtofino in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 06-17-2010, 00:39
