TheDieselPage.com Forums
The Diesel Page Forums
2020 - TDP's 24th Anniversary
Go Back   TheDieselPage.com Forums > The Diesel Page Forums > 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance 1992-00 6.5L Turbo Diesel - Welcome to the Internet's first discussion forum for the 6.5L diesel engine. Tips on performance, upgrades, cooling, fuel economy, troubleshooting and more.
Reply
Thread Tools Display Modes
  #1
Old 02-10-2020, 03:27 PM
Bill D Bill D is offline
Newbie
Default Out of ideas trying to start a 98
Still trying to start 98 6.5 problem is I can pull glow plugs from heads and get a mist but when I try to start I get no smoke out the back end and it doesn’t even act like it wants to start also have all new Bosch plugs. The batteries are old 2014 but it still turns over, however when I check voltage I have 12.1, I took them to advance and and got 513 and 423 cca my question is is there a min voltage the pmd needs to spray fuel I think with cranking under load (with the plugs in) and heating glow plugs could it be pulling voltage down to much for the pmd
  #2
Old 02-10-2020, 05:57 PM
sctrailrider's Avatar
sctrailrider sctrailrider is offline
Diesel junkie
The motor needs to turn over fast, with old batteries it may not be spinning fast enough...
__________________
1993 Chevy K3500
like us on Facebook
  #3
Old 02-10-2020, 06:20 PM
Newbie
But shouldn’t I still get smoke out the back?
  #4
Old 02-10-2020, 08:22 PM
JohnC's Avatar
JohnC JohnC is offline
Proud Deplorable
With the electronic pump there's no fuel until you break minimum RPM. It might be 200 RPM, but I'm not sure any more. What's the battery voltage(s) at cranking speed?
__________________
"Need" - Wanting to get someone else's money.
"Greed" (formerly meant what "need" means today) - wanting to keep your own.
"Compassion" - a politician's willingness to arrange the transfer.
-Joseph Sobran
Current oil burners: MB 350SDL, Kubota 7510
Gone but not forgotten: '87 F350 7.3, '93 C2500 6.5, '95 K2500 6.5, '06 K2500HD 6.6
  #5
Old 02-11-2020, 10:47 AM
CoyleJR CoyleJR is offline
Enthusiast
Bill D,
You indicated that there was no smoke from the back. Check your air intake and exhaust system, a small mouse nest can cause big problems.
Good luck
John
__________________
*2007 Pontiac Solstice.
  #6
Old 02-11-2020, 01:48 PM
More Power's Avatar
Administrator
Try plugging in the block heater for a few hours before the next attempt to start it.
  #7
Old 02-13-2020, 10:11 AM
Big Green Big Green is offline
Enthusiast
I believe min crank speed is 400rpm.
Big Green
  #8
Old 02-16-2020, 02:26 PM
a5150nut's Avatar
a5150nut a5150nut is offline
Enthusiast
I had a 94 that did that to me at that grocery store. Sounded like it was cranking fast enough but wouldn't hit minimum RPM to get the fuel solenoid to open. Have someone crank it while you have you hand on the solenoid and see if its clicking open. If it doesn't it time for batteries. Make sure the solenoid works first.
__________________
-Patrick Henry
A5150nut
2006 K3500 D/A
94 6.5 4x4 5spd Sold
  #9
Old 03-15-2020, 08:56 AM
phantom309 phantom309 is offline
Enthusiast
A 6.5 starts best when its whizzing over,. Slow rpm equals poor injector pressures,.pull couple of glows and manually verify they are working well
__________________
1999 chev suburban C2500
300,000 mi
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Thread Thread Starter Forum Replies Last Post
Cold start problem. DIESEL/VETTE Duramax 6600 7 03-25-2015 01:08 PM
6.5TD Will Not stay running, Hard to start, then shuts off after bucking/kicking? 97Suburban 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance 2 02-11-2015 07:46 PM
Hard to start DIESEL/VETTE Duramax 6600 2 10-29-2013 01:23 PM
Won't start. Ideas needed-Please take a look restoguy 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance 4 04-23-2008 06:57 PM
'01 Dmax getting harder to start chessy56 Duramax 6600 7 01-23-2008 06:33 PM
