Results 21 to 40 of 43
Thread: 6.5 TD Highway Mileage Poll by GMC Hauler
  1. #21
    Lubbock TX, USA
    mite as well contribute rite?
    1. Suburban:
    2. 2500
    3. 4x4
    4. 2
    5. 2
    6. none
    7. 42 gal
    8. 4.10
    9. 245/75 R16
    10. Highway
    11. No
    12. factory
    13. factory 9psi observed.
    14. Automatic Trans
    15. 180 Dual
    16. Stock F
    17. No
    18. No
    19. No
    20. 97 a/b Purolator Paper
    21. Vin F, non-egr
    22. GM-4
    23. 4"
    24. stock - .7
    25. stock pop injectors
    26. No, Delo 15w40
    27. 16 mpg
    28. Winter
    29. 100k
    1986 C10 SCLWB 6.2TD 3.73 700
    1989 V20 SUB 6.2NA, 3.73 400
    1994 G20 VAN 6.5NA, 3.42 60E
    1996 K30 DRW 6.5TD 4.10 80E
  2. #22
    Mar 2005
    Bremerton, WA
    Please post your results and how you came about to calculate everything. Here is my rig's info.
    1- pickup, regular cab, long bed
    2- 3500 dual rear wheel
    3- 2x4
    4- 2
    5- 1
    6- 12 oz of diesel kleen or lucas oil
    7- 36 gallons
    8- 3.73
    9- 235/85 R16
    10- Highway
    11- not installed
    12- mechanical boost control
    13- 0-10lbs. 12lbs max
    14- manual trans nv4500
    15- 195 degrees
    16- no pcm. DB2 pump
    17- yes
    18- no, in the works though
    19- no
    20- K&N round element
    21- non EGR
    22- GM-3
    23- BD 4"
    24- stock I guess. don't know with DB2 pump
    25- hi pop.
    26- no
    27- 20.8 highest avg.
    28- summer
    29- truck has 234k. engine has 34k.
    I use propane on the highway. MPG figures are with propane use.
    -*og%rice*-
    93 C3500 dually 6.5td. 18.7:1, Balanced, Coated, Underdriven, BD 4" exh, Turbomaster, 2 gage pillar + 3 gage dash, Dual electric fans, DB2 4911(maxxed out), NV4500, Propane, 97' cooling, Pre luber aux oiling, Phaser timing gears, hand made glow plug wiring harness 10ga. fluidampr damper, two pass FMIC, more to come..............
  3. #23
    Oct 2003
    Maine
    Default The data crunching is complete.
    I have finished putting together the data. I had to fit the data as best as possible. I assumed 195 is the stock
    thermostat setting (if it is different, please advise). Also, Ogrice, I did not use yours becasue of the propane use,
    it would introduce too many variables.
    As you can see, i had to break it up into 2 sections, because it was too long.
    This is sorted top to bottom from highest mileage to lowest. Most of the lower gear ratios (3.23) were concetrated near the top.
    The 4.10's were sprinkled throughout, which was surprising.
    The other trend I noticed is that the higher mileagers were electronic boost control, where the lower mileagers were dominated by mechanical.
    I have been thinking of switching back to electronic boost control for this reason, although I don't want to use the factory vacuum pump.
  4. #24
    Nov 2001
    Aitkin, MN
    Good Day!
    Any chance of getting this in spreadsheet form? If so, you could private message me your real email address, & I'd give you my real email address, to which you could attach this spreadsheet to an email.
    Looks like that moondoggie feller is near the top. Did he tell you he's a pathological liar?
    Blessings!
    (signature in previous post)
  5. #25
    Oct 2003
    Maine
    Quote Originally Posted by moondoggie
    Good Day!
    Blessings!
    You've got mail.
    Everyone can get it in spreadsheet form if they wish, just PM me your email address.
    I can continue to add data. I'll do it in batches of 5 as it is entered.
    The next update I make wil have an overall gear ratio instead of the tire size and rear end ratio.
    Alot more accurate that way.
  6. #26
    May 2001
    Arlington,WA,USA
    1. 1999 Suburban
    2. 2500
    3. 4x4
    4. 1
    5. 3
    6. 12
    7. 42
    8. 3.79
    9. 235/85R16
    10. M/S
    11. no
    12. stock
    13. stock
    14. Automatic
    15. 195 (180 is stock)
    16. BD
    17. no
    18. no
    19. no
    20. stock airbox, Amsoil filter
    21. Non EGR:
    22. stock (GM8?)
    23. 4", no kitty
    24. stock
    25. stock
    26. Delo 400 (quasi-synthetic)
    27. 18.7
    28. summer
    29. 138000
    1999 GMC Suburban 6.5LT
    AMSOIL 2 stage air filter, 4" free flow exhaust, ISSPro pyro & manifold pressure, FSD Cooler, BD computer, Bilstein shocks, Headlight harness, Evans NPG+ coolant
  7. #27
    Sep 2006
    Brooker, FL
    Everybody's got something so, so, NORMAL...
    1. '94 Barth ["What the HELL is that?"] 28' Breakaway Class A motorhome
    2. 8500? (I dunno, it has a GVW of 18K lbs.)
    3. 4x6
    4. 1 (As if there's anything else as an option)
    5. 1
    6. Injector cleaner and/or ATF only
    7. 40
    8. Dana 80 4.53 (I think - Mag-Hytec cover installed)
    9. 8x19.5
    10. Mixed
    11. Gear vendor? Nope - no room and unnecessary
    12. Boost control: Purely Stock
    13. Same as 12.
    14. Automatic Trans 4L80E (Mag-HyTec pan installed)
    15. Thermostat: 2x195F (Kennedy Diesel kit installed)
    16. N/A - DB-2
    17. Timing Gear: N
    18. Intercooled: N
    19. Mist injection: N/A
    N20. Air filter: Stock Wix, but this diesel pusher has far less restrictions - "Snorkle" is 4"
    21. Non-EGR
    22. GM Turbo Style: 5
    23. Exhaust: 4" Turbo to ground
    24. TDC offset set to : Stock
    25. Stock injectors
    26. Synthetic oil: N Total waste of money (I'm a former fuels and lube engineer)
    27. Highway mileage: 9.8 mpg
    28. When mileage data was obtained: Summer
    29. Approx miles on vehicle: 52,500
  8. #28
    1. Truck long bed extended cab
    2. 2500
    3. 4x4
    4. 3
    5. 4
    6. none
    7. 34 gal
    8. 4.10
    9. 245/75/16
    10. Mud/Snow
    11. no
    12. factory
    13. factory (I think 9 psi)
    14. manual
    15. none
    16. stock
    17. stock
    18. no
    19. no
    20. Factory
    21. non
    22. stock
    23. 4"
    24. stock
    25. stock
    26. no
    27. 16
    28. summer
    29. 243000 (43000 after overhaul)
  9. #29
    May 2001
    Peace Dale, RI, USA
    Talking
    1. What model: 1993 Chevrolet Silverado long bed, extra cab.
    2. Level 2500HD (eight lug hubs)
    3. 2x4:
    4. Driving Habits; 2
    5. Tune of vehicle; 3
    6. Fuel additive added every fillup in OZ; 6oz Stanadyne or Howes + 2cycle oil
    7. Size of fuel tank: 34gallon
    8. Rear Gear Size: 3.42
    9. Tire Size:245/75 R16
    10. Tread style; Mud/Snow
    11. Gear vendor?: No
    12. Boost control; Mechanical-Heath
    13. Boost pressure setting: 11psi
    14. Manual/Automatic Trans: Manual, 5spd
    15. Thermostat: 180*F
    16. PCM programming: No computer!
    17. Timing Gear Y/N: DSG geardrive
    18. Intercoooled Y/N: No
    19. Mist injection Y/N: No
    20. Air filter: SS Diesel Supply K&N style
    21. EGR/Non EGR: No EGR
    22. GM Turbo Style: GM-8
    23. Exhaust: BD 4" with 3" downpipe
    24. TDC offset set to: NA
    25. Stock injectors/High pop: Stock
    26. Synthetic oil Y/N: Yes
    27. Highway mileage (not towing, best averaged over 3 tanks): 19.2mpg
    28. When mileage data was obtained (Winter, Summer): Summer
    29. Approx miles on vehicle: 241,000
    RT
    93 C2500HD, ExCab, 6.5TD, 5speed, 3.42's, Isspro gauges, Banks/BD exhaust, DSG Geardrive, GM 8 with Turbomaster boost controller, advanced/turned up pump.
  10. #30
    Default 310 Chassis, TYMCO Sweepers (4)
    1. 310 Cab/Chassis (135.5" Chassis) with TYMCO Sweepers 96-98-99-00
    2. 3500 DRW
    3. 2x4
    4. Employees (4.5)
    5. Runs (3)
    6. Nada
    7. 20?
    8. 410
    9. 235/85-16
    10. M/S
    11. None
    12.Stock
    13.4
    14. Auto 4L-80E
    15. 195
    16. N0
    17. N0
    18. N0
    19. N0
    20. Stock
    21. EGR
    22. Stock
    23. Stock
    24. Stock
    25. Stock
    26. No, Rotella
    27. Only have fleet avg mileage: 8.67
    28. Last fleet report (Oct 06)
    29. Approx miles on vehicle: 245,000, 230,000, 195,000, 183,000
    These trucks get the worst abuse you can dish out. Low speed parking lots, then high speed runs. Operators understand: start, drive, stop. The whole "how diesels work" escapes them. Repairing a broken frame today....weeee....
  11. #31
    Jan 2004
    215 Winter Street
    Thumbs up
    I had to post results. It works. I have never driven consistent enough to record numbers any better than 17 MPG but today I went on a 278.2 mile ride on 13 gallons of fuel and got 21.4 MPG. Stayed at 1800 RPM which is 65 MPH with 3:42 rear gear.
    1. 1999 Suburban LT
    2. 1500
    3. 4X4
    4. 1 on this ride
    5. tune is #1
    6. Kennedy mix of cetane and lubricity
    7. 42 gallon
    8. 3:42
    9. 245/75/16
    10. mud/snow
    11. none
    12. Peninsular non waste-gate
    13. "
    14. automatic
    15. 195
    16. Heath Computer
    17. timing chain set
    18. Kennedy Intercooler
    19. no mist
    20. Kennedy Air Box
    21. no EGR
    22. Peninsular non waste-gate
    23. Kennedy 3.5 system, coated cross over and coated manifolds
    24. -1.94
    25. high pop
    26. Amsoil 15/40
    27. 21.4
    28. 164K truck 2500 Peninsular 18.1 engine
    1999 6.5 Suburban LT
  12. #32
    Oct 2002
    British Columbia
    1. c/c l/b
    2. 3500 dually
    3. 4x4
    4. 4
    5. 1.5
    6. Shaffers one capfull every fill
    7. 35 Gall
    8. 4:10
    9. 225/75 16
    10. Highway
    11. No
    12. Boost fooler (elec)
    13. 15lbs(pulling)
    14. Automatic
    17. No
    18. Yes
    19. No
    20. Aftermarket
    21. egr
    22. GM-8
    23. 4"straight
    24. Stock
    25. High pop
    26. Yes
    27. 18 empty
    28. summer
    29. 200,000 km
    98 c/c l/b 4x4 dually 6.5td i/c,boost cntrl,boch h/f,4in straight ex,boost/pyro guages &h/f air
  13. #33
    1. Truck Extended Cab SWB
    2. 2500
    3. 4x4
    4. 3-4
    5. 1
    6. none
    7. Stock
    8. 4.10
    9. 265/75R16
    10. Mud/Snow, Highway:
    12.None
    13. 6-7 cruise, 18 WOT
    14. Automatic Trans:
    15. Stock
    16. Westers
    17. Stock
    18. Stock
    19. N
    20. Stock
    21. Non EGR:
    22. Stock
    23. mufff removed, kitty removed, 3"
    24. -1.24
    25. Stock injectors
    26. Castrol 5W50 Synthetic
    27. 24-26
    28. Summer
    29. 378,000 kms
    Lyndon
    www.ecmprogrammer.com
    Westers Garage
    '98 6.5TD VIN "F", '01 C5 Convertible, '04 LLY, '05 SSR, '05 Yukon
  14. #34
    Apr 2003
    Michigan
    1. Long bed extended cab
    2. 2500, Single
    3. 4x4
    4. 3
    5. 1
    6. Bio diesel pump gas,
    7. 36
    8. 4.10
    9. 235 85 R16
    10. Mud/Snow,
    11. N/A
    12. Custom Electrical:
    13. 15 psi
    14. Manual
    15. 195 winter, 180 summer, large diameter dual setup, 130 GPM pump
    16. N/A
    17. N:
    18. Y: custom made
    19. N
    20. Stock mod, KN filter
    21.Non EGR:
    22. GM-8
    23. 4
  15. #35
    Oct 2003
    Maine
    Updated.
    We'll see how I move up... Installed new injectors and KD glow plugs a few weeks ago.
    d.h., could you provided the missing information?
  16. #36
    Aug 2005
    Alexandria, IN
    BE CAREFUL!!!
    I think that ECM programmer is quoting "Canadian MPG", which uses a different sized gallon that we us in the US (4.456L CA gallone versus the 3.785L "US gallon"). APPLES TO ORANGES comparison with his results. His results should read "20.4 to 21.1 US MPG" to be apples to apples, which is still great fuel economy but much more realistic than 25MPG!!!!
    Please also note that he quotes the odometer reading in "kms", which is an additional clue...
    1994 Chevrolet K3500HD; Crew Cab; 6.5TD Vin F; 5 speed manual; 201K miles, Homemade WG control...
  17. #37
    Oct 2003
    Maine
    Quote Originally Posted by gherrell
    BE CAREFUL!!!
    Good catch...
    Gove me a few days to make some adjustments..
    Those of you who post in KM, please make it obvious to me so i don't miss it.
  18. #38
    BE CAREFUL!!!
    Actually it's 1.201 of the US Gallon. 20.8 US MPG.
    kms to miles is 1.62 ratio
    I could confuse you further with litres consumed per 100kms....
    Lyndon
    Westers Garage.
  19. #39
    Aug 2005
    Alexandria, IN
    Quote Originally Posted by ECMProgrammer
    Lyndon
    Westers Garage.
    Well, your original post specified a RANGE of 24 to 26 MPG (Imp). Which, if converted to US gallons, would be 19.98 to 21.64 MPG (US). And trust me, you would not confuse ME with L/100km's. If you really wanted to confuse people, then give your fuel economy in furlongs/firkin (*0.88888889)
  20. #40
    Dec 2006
    Absarokee, Montana
    Default Mileage Survey
    1. 93 GMC 6.5 Turbo Diesel, extend cab, long bed pickup.
    2. Sierra 2500HD
    3. 2x4
    4. 2
    5. 2
    6. No
    7. 42 gal.
    8. ?
    9. 235/85 R16 10 ply Cooper Discovery.
    10. Mud and Snow.
    11. ?
    12. ?
    13. ?
    14. 5 speed manual transmission.
    15. ?
    16. ?
    17. ?
    18. ?
    19. ?
    20. Stock
    21. ?
    22. ?
    23. 3" straight pipe.
    24. ?
    25. ?
    26. Natural oil, Shell Rotella.
    27. 22 m/gal.
    28. Fall/Winter.
    29. 70K.
