Thread: 89 burb w/ 6bt nv4500 np205
    Jun 2009
    Default 89 burb w/ 6bt nv4500 np205
    check my in-progress build @ pirate
    1989 3/4 suburban, soon to be cummins
    (17 gallon wvo, lifted 5", 33" toyos,
    4.11s, 170amp alt. & 6 disc chager,
    & some other goodies)
    1998 jeep cherokee (for sale)
    Sep 2006
    Welcome to the Cummins powered Suburban club! Your Suburban looks almost identical to mine but with better paint. I checked out your post at the following link and it looks sweet.
    http://www.pirate4x4.com/forum/showthread.php?t=851657
    You'll be glad that you went the manual transmission and bullet proof np205 transfer case route. The automatic transmissions that were mated to the Cummins on Dodge trucks were junk. Before you bolt that engine all back together, make sure you do the dowel pin upgrade. What turbo are you planning to use?
    1990 ¾ ton 4x4 Chevy Suburban
    -Gear Vendors Overdrive
    -Upgraded Holset HX-35 turbo
    -NP205 iron transfer case
    -3.73 gears
    1982 ½ ton Chevy Suburban
    -Stans headers
    -Ported heads
    -Timing gear
    -4 speed automatic
    -3.08 gears
    -30 mpg on freeway
    Jun 2009
    ya dowel pin already fell out. i got a holset 18cm h1c
