Results 1 to 2 of 2
Thread: WTB - 96' to 00' Cruise Control Parts for 6.5
    Apr 2007
    West Michigan
    Default WTB - 96' to 00' Cruise Control Parts for 6.5
    Wanted to buy:
    Cruise Control column stalk controls & wiring pigtail/plug(s) for 1996 thru 2000 Chevy 6.5 diesel truck.
    We want to convert non-C.C. to Cruise and understand that all it takes is the lever/buttons.
    Am looking for two of these assemblies if possible.
    Location – Kalamazoo, Mich.
    Thanks a bunch.
    '96 c2500 Suburban 2wd
    All stock w/'97 Cooling, FSD Cooler
    '00 c3500 Base Truck 2wd
    Large exhaust, Jasper towing 4L80E
    Gauges, FSD Cooler, Bambygone lites
    Jul 2003
    Allentown, PA
    I *think* that you can use a cruise control set-up out of a gasser, as well. If so, that would certainly make it much easier to find - like at junkyards. It may have been talked about here on the forum before - try a search. Or, just call a dealer. But, yes, that is all that it would take. The programming is already in the ECM.
